Cycles Standalone not respecting integrator sample_clamp_direct #47813
Closed
opened 2016-03-16 03:33:51 +01:00 by Jeff Witthuhn · 11 comments
Windows 8.1 64-bit
Broken: Latest git from the Cycles standalone repository. At this commit https://developer.blender.org/rCae057c51edfc85661574b0db5cf411b5d145ffbb
Cycles standalone does not clamp sampled values, regardless of the integrator's sample_clamp_direct value.
Cycles does respect this value when set through the blender UI in 2.77RC2. Only cycles standalone has this issue.
Attached a short xml file to reproduce this in Cycles standalone. It contains a cube with an emission shader of strength 10, and sample_clamp_direct set to 0.5. This should produce a render of a gray cube, but instead it will render white.
scene_cube_test.xml
**System Information** Windows 8.1 64-bit **Blender Version** Broken: Latest git from the Cycles standalone repository. At this commit https://developer.blender.org/rCae057c51edfc85661574b0db5cf411b5d145ffbb **Short description of error** Cycles standalone does not clamp sampled values, regardless of the integrator's sample_clamp_direct value. Cycles does respect this value when set through the blender UI in 2.77RC2. Only cycles standalone has this issue. **Exact steps for others to reproduce the error** Attached a short xml file to reproduce this in Cycles standalone. It contains a cube with an emission shader of strength 10, and sample_clamp_direct set to 0.5. This should produce a render of a gray cube, but instead it will render white. [scene_cube_test.xml](https://archive.blender.org/developer/F293239/scene_cube_test.xml)
Author
Author
Added subscriber: @witthuhn
#48121 was marked as duplicate of this issue
Thomas Dinges self-assigned this 2016-03-16 16:27:15 +01:00
Will check.
Will check.
Author
I took a closer look at this and it seems the problem was that the scene's Film::use_sample_clamp must be set to true for either direct or indirect clamp to work, it defaults to false and isn't exposed through the XML api.
Yes, that is the reason, but it's not clear yet to me how to properly fix this. Ideally we reshuffle some code, so setting this flag happens in /render and not in the exporter (Blender or XML).
Added subscribers: @Sergey, @esminis
This issue was referenced by 9604db7650
This issue was referenced by 9604db76505fb832252776810edc430c9159542a
This issue was referenced by blender/cycles@5722030a8e
This issue was referenced by blender/cycles@5722030a8e74996cfcea688bdb688309a1976db4
Reference: blender/blender#47813
