No antialiasing in Direct/Indirect passes #48050
2 Participants
Reference: blender/blender#48050
winds 7 64bit
Broken: blender2.77
22a2853
just render with the Direct/Indirect passes check on.
I don’t know this is bug or not, or it’s should be this, if the Direct/Indirect passes can antialiasing will be much better for the post processing, like use the indirect pass for denoise.
Added subscriber: @Leroy-Xie
Added subscriber: @brecht
This not a bug, it's a side effect of splitting the direct/indirect and color passes. Either direct/indirect or color must have such "aliasing" issues for the multiplied results to be correct, there's no way around that.
I don't know that having a smooth direct/indirect pass is in fact better for denoising when viewing the result after multiplying with the color. Maybe if you use a simple blur filter but even then, you would get too much color bleeding from the background regardless, and with a smooth direct/indirect pass that would be worse.
A smart denoising filter could figure out not to blend across these boundaries, and having a clear boundary helps to avoid the background bleeding in.
