No extension on frames saved as PNGs #48052
2 Participants
Reference: blender/blender#48052
Windows 8.1, nVidia GT740
Broken: 2.77
Worked: 2.76b
Frames saved without the proper extension (.png in my case)
Import a movie, select a frame range, (choose PNG as the output file format), press Ctrl+F12
The frames are saved WITHOUT the extension!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Now, who tells me that this is a feature or that he can't reproduce the bug?!
Added subscriber: @BugFinder
Added subscriber: @mont29
Suggest you stop your bullshit and learn how to use Blender instead. No, I cannot reproduce it - not with default startup at least, if I disable relevant option (
File Extension
in Output panel of render settings) I do get extension-less files, that’s for sure. It would be a bug if I didn’t, actually.Since you did not follow our submission template and guidelines and did not made a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc., I’ll just assume afore mentioned setting is the culprit and close that report, next time try to avoid losing our time and do your own home work first.
I suggest you calm down.if I disable relevant option (File Extension in Output panel of render settings) I do get extension-less files
You know what? I didn't!! After upgrading, I selectedUse the previous settings file
from the Splash screen. Isn't it supposed to load ALL my previous settings, includingFile Extensions
?Since you did not follow our submission template and guidelines and did not made a complete, valid bug report, with required info,
I filled in all the REQUIRED infos. You're asking for an optional step. Which is easy to reproduce, given the spes I illustrated (or do you prefer me sending you a .blend file which icludes a 640 MB video?)Try to be more friendly.
Thank you.
