sampling is buggy in 2.77 #48418
6 Participants
Reference: blender/blender#48418
Win7 x64
Broken: 2.77a
Worked: 2.76
Low sample (16 and lower) images are noisy on edges
bug sampling edges 2.77.blend
Open attached file in 2.76 and 2.77a, compare you get this in 2.76
and this in 2.77a
Added subscriber: @john_hannovick
Added subscriber: @NikoLeopold
Added subscriber: @Sergey
Can't reproduce the issue. Some questions:
Attaching system-info.txt generated with
Help -> Save System Info
would be handy too.Added subscriber: @bliblubli
I can confirm the bug. But the attached file with 16 samples make it less clear, at 4 sample it is obvious that edges are very noisy compared to 2.76b. Note that you may have to zoom on highDPI screen to see the difference.
Changing from Blackman-Harris to Gaussian doesn't solve the problem.
2.77:
2.76:
@bliblubli, what's your OS, compute device and system-info.txt?
Win 7 x64, CPU and the sys-info:
system-info.txt
Tested it on many PC with windows:
Bliblubli is true. It's easier to see the problem at 4 spp than at 16.
The noise is most visible on edges, but it also affect faces. It's a pretty big regression actually regarding noise.
After a lot of reverts and checkout of old revisions, I nailed the problem. https://developer.blender.org/D2021 fixes the regression.
Of course, it makes rendering with HDR noisier. A better fix would be to detect "generated sky" and "HDR" to activate MIS only for HDR.
Another point is: Why does MIS break edges antialiasing?
With 1 sample:
Without MIS (pre 2.76.10)
With MIS (after 2.76.10)
Added subscriber: @mont29
Added subscriber: @LukasStockner
As far as I can see, this is no bug, but simply how path tracing and World MIS works:
If you have no world MIS enabled, each path samples the lamp in the direct light sampling step amd then bounces and hits the background. Both give pretty similar results each time, so you get a clean image.
With World MIS, Cycles now sees two lights to sample (the lamp and the World) and will choose randomly between the two, producing darker pixels when it sampled the World.
It's unfortunate, but that's just how the algorithms work, no bug happening there.
So, how to "fix" this? The easiest option would be to use branched path tracing and enabling sampling of all lamps.
I agree it's how MIS works, but thing is it should be smartly activated. Just changing default like that make some old files look suddenly really noisy without the user knowing why.
There are already conditions added by Thomas to deactivate MIS in the code for uniform color background, adding the generated sky exception would do the job.
This is a documented change in 2.77 - [x]. There's also a do-versions code which should keep files saved in previous releases to render exactly the same way. If there's file which was saved in previous release and renders differently in new one -- this is to be reported and fixed.
Excluding generated sky from MIS is not really correct, there might still be strong highlights on it.
Wouldn't really consider this a bug. Just for a simple scenes you can disable MIS. And defaults we'd better be enabling based on heavy production shots.
Thanks for the report anyway.
