fail to render texture for .obj+.mtl on Mac OSX #48423
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#48423
OSX 10.11.2, NVIDIA GeForce GT 750M (also test Macbook with integrated graphics card)
Broken: blender-2.77a
When load .obj + .mtl models, the texture cannot be rendered correctly on OSX.
But same 3d model file works well on linux with blender-2.77a.
Added subscriber: @comipayan
This is the correct render on linux:
Added subscriber: @mib2berlin
Hi, pleas add your .obj/mtl files here.
You can drag and drop it to the text field.
Cheers, mib
Added subscriber: @mont29
Hi mib,
Here's the chair model.
chair_model.zip
I also found .obj model download from ShapeNet(http://shapenet.cs.stanford.edu/) also cannot be rendered normally.
Here's another example:
ShapeNet-PlaneModel-02691156.zip
The result looks like this:
Nothing wrong with Blender here, it’s that obj file which is merely garbage (UVMap is pure nonsense, and geometry itself has very bad things like degenerated faces, which break normal computation)…
The issue is why blender version on OSX cannot render correctly, while linux version can make it though there's ``garbage'' in obj file.
