Cycles Glossy BSDF Specular issue #48485
2 Participants
Reference: blender/blender#48485
System: Windows 7 64bit
RAM: 4096 MB
renderer: 'GeForce GTX 760/PCIe/SSE2'
vendor: 'NVIDIA Corporation'
version: '4.5.0 NVIDIA 364.72'
Broken: 2.77a
Cycles Glossy BSDF Specular changes into material color, instead of
light source color if the material color is "pure"
The Cycles Glossy BSDF Specular should reflect the light source color,
instead of material color, when one or two of the rgb values are set
to 0, i.e. pure red rgb 255,0,0 or orange rgb 0.394, 0.153, 0
Pure black rgb 0,0,0 doesn't have any specular color at all, which
was intended I belive.
Cycles-Glossy-BSDF-Specular-issue.blend
Cycles-Glossy-BSDF-Specular-issue.mp4
Added subscriber: @MichaelParucha
Some light color and material color combinations don't give any specular at all.
You can change the light from green to something other and then try to set the material color and again in some color combinations, there will be no specular at all.
Cycles-Glossy-BSDF-Specular-issue-2.blend
Added subscriber: @brecht
I don't see any bug here, if you specify zero for one of the R, G or B channels it will reflect zero light for that channel.
If you want your material to have a white specular coat (as many real world materials do), then you should use a white glossy BSDF, layered over another diffuse or glossy BSDF. That is not included in a colored glossy BSDF somehow.
The only reason it appears white even with small but non-zero R, G or B channel is because the specular is very bright, and all pixels will end up with value > 1 and so are all clipped to 1. That also depends on the chosen view transform in color management by the way, the default is not the most realistic.
