VSE audio pitch changes the speed of the audio #48505
5 Participants
Reference: blender/blender#48505
Windows 10
Intel HD 4600
Broken: Master
VSE audio pitch changes the speed of the audio along with pitch. This is a little weird, if the functionality is correct then the option should be titled "Speed"
Added subscriber: @Blendify
Added subscriber: @Sergey
It's always a good idea to attach exact .blend with exact audio file which demonstrates the issue.
Please do a little more research before opening bug reports like this.
What Blender offers here is called pitch control and changes speed and pitch at the same time, as it is a rather simple process that has been around for a long time. Traditionally, it has always been called just "pitch" in Blender since before 2.5 (when I started developing for it) most likely a lot longer. As the proper term is pitch control and not speed control, even though it changes both, "pitch" is the correct naming.
Controlling only either of those values is called time stretching, pitch scaling or pitch shifting (the last term is a bit ambiguous as it is also sometimes used for pitch control). This process is more complex and not currently supported by Blender.
Before reporting the bug a cross-referenced it with Audacity and it has 3 controls:
Added subscriber: @ChristopherAnderssarian
Added subscriber: @hk1ll3r
I'm new to blender, not sure if this is the right place but here I try...
I'm using blender 2.79b and the pitch only changes the pitch. To the length of the audio stays the same and it plays all the way through the strip. The new behavior is inconsistent with what is being discussed here... according to @neXyon 's terminology, blender does pitch control (speed and pitch at the same time) where as I'm seeing only a pitch change (pitch scaling).
Has this behavior changed since? Can you reference the bug / task? Thanks.
@hk1ll3r, instead of re-opening old reports, make a new one. With all the information requested there.
Please note that this is not really a place for discussion, but for a bug tracking, where artists report reproducible bugs and developers fix them. For discussions there are other channels like devtalk.blender.org, or blender artists.
@hk1ll3r, you're right the strip length stays the same, but that doesn't mean that the speed doesn't change. If you have a strip of full length (not cut on any side) and you change the pitch to 2, you'll end up with double pitch and double speed, but the strip will stay the same length, meaning that it's silent in the second half. We intentionally don't change the strip length when the pitch is changed, since this can cause many problems, especially when you animate the pitch. I hope this clarifies the issue. If not, please ask further questions on devtalk.blender.org as @Sergey suggested.
