Pie Menus initiated by tweak events will disable the mouse button used in the tweak event. Works fine for regular menus, operators. #48541
Reference: blender/blender#48541
Windows 10
geForce GTXTitan
Broken: blender-2.77.0-git.94e18c5-AMD64
I've set up some UI shortcuts that use 'tweak' events (or directional gestures) for various pie menus, regular menus, and operators. This work fine for regular menus and operators. After calling a pie, however, the tweak button defined in the input editor (left, right, middle, action) becomes unusable.
Open User Prefs, select the add-ons tab, and enable Official Pie menu addon
Select the 'Input' tab in User Prefs, and in the keymap filter (set to name), type the the word 'pie' without quotes
The first filtered pie is 'Frames'. change the hotkey as follows:
Click the event mapping dropdown (its set to keyboard by default), and change to Tweak. two new options appear next to it: 'Left', and 'Any'.
Change the type of event, or leave it as 'Left'
Change 'Any' to a direction.
Select a modifier key such as Shift
go to the 3d view and execute the new shortcut you set up. The playback options should appear in the pie menu but are not selectable. Hitting the escape key will get out of the pie, but the defined tweak button is not usable.
NOTE: If you use the default right click select, you can still place the cursor, but can't trigger the shortcut again. If left click select is set, then normal tweak events like moving selected objects are also not possible.
NOTE: Toggling Object/Edit mode will make the button usable again.
Added subscriber: @fjg3d
Added subscribers: @JulianEisel, @Sergey
@JulianEisel, something for you? :)
Added subscriber: @SimHacker
Added subscriber: @mano-wii
The problem is also seen in the 2.82 pie menu system.
But I don't think it will be fixed anytime soon.
So I'm marking it as
