Extending python handlers #48601
Reference: blender/blender#48601
A large part of Blender logic is implemented through operators' calls. And sometime it is necessary to handle such events.
For Blend4Web this feature is important more for user usability now. For example adding new custom node tree for Logic Editor in Blend4Web needs some handle (set this tree as default). And we also have some custom properties that could be set automatically after some event.
I've made an attempt to solve this issue here D2052. Hooks are implemented for all Blender operators, and such freedom can bring bad consequences, first of all in performance.
I see the following ways for improvements:
Added subscriber: @ideasman42
@AlexanderRomanov, could you describe some use cases for this feature?
What you've described in your description is a bit vague and doesn't help so much in finding a general solution.
For example - if you need to set a tree as default after adding, could this be added as an option into Blender? (or is this a setting you maintain).
Regarding having callbacks on each operator (as with the patch, but filter by operator identifier).
If we add this kind of feature, its going to be used (and abused) for all sorts of cases.
So I like to see 4-6 examples where this feature is a good solution to some problem, not just some hack which allows to insert Python-calls into any tools to solve some corner cases.
Actually I think that this is a general solution. Because you can handle any event.
For custom node trees, actually it is preferred to have generalized UI for linking it to any datablock (Linking Custom Node Tree to DataBlock ).
Partially this issue could be solved with D113, and I'm working on this patch now.
We can agree on a set of useful operators and hardcode them. But this will be a strict limit on generalization
My point:
"Make another handler system for operators only (where callbacks are stored in the list inside the concrete operator type)"
So callbacks will be invoked only for specific operators. This is better for performance.
I find it difficult to show so many examples. And yes, all this cases are corner cases.
Added subscriber: @brecht
I don't have clear ideas on how to solve this, but since this came up in D2137 I'll give my opinion. I'm not sure if it will help you right now since it's a complicated topic..
There two systems for detecting changes in Blender:
In general, it's difficult to exactly describe a change. You might want to find out when a datablock is added. But should that be triggered on copying, on replacement, on appending, on joining, ..? It depends what you need to do exactly.
When the addon should act is also tricky. Right after the datablock is added or before it is deleted while the operator is still running seems very fragile and potentially a big performance problem. After the operators has finished running seems like the more reliable, but at that point it is difficult to precisely describe how the datablock was modified, or it might have already been deleted, copied, etc.
This is very rough, but imagine we remove the notifier system.
DAG_id_tag_update
could get extra flags:Datablock "UI state" changed (selection/hiding/mode). Datablock was newly added.
** Maybe a few more, but keep it as limited as possible.
Added subscriber: @ckohl_art
