Crash when using Ctrl-Z on the Render layer #48604
Asset Browser Project (Legacy)
Asset System
Reference: blender/blender#48604
Win 10 Home 64bit, 3.4 Ghz Intel I-7 6700, 16 gig RAM, GeForce GTX 745, 4 megs.
Also tested on a Win10 Home 64bit, 3.1 Ghz Intel I-5 4440, 8 gig RAM, no GPU card.
Broken: 2.77a
Worked: N/A
Crash when using CTRL-Z to undo on the layer to be rendered. VesselModel_03.blend
The crash doesn't happen with earlier files of this model (VesselModel_01.blend and VesselModel_02.blend). It appears that something is corrupting this file and it has been passed on to other files that were modified and saved from this one.
Added subscriber: @jjfeenix
Added subscriber: @mont29
Can confirm the issue.
Crash seems to happen because a scene's base is freed during cleanup step of undo, while actually being in use by the scene…
Also, 2.77a release crashes, but not 2.76b…
OK, so this heavily simplified file still crashes on undo… will be much easier to investigate. ;)
VesselModel_03_simplified.blend
Arf, finally found the culprit, was in drawing code actually…
This issue was referenced by
055001111e
So now what? I'm pretty new to Blender and have never turned in a bug before. Is there are fix for what ever ails 2.77a?
Before I saw your Simplified file, by process of elimination, I narrowed it down to the spotlights. I transferred the file to a Win 7 machine with 2.76b installed and was able to move all 4 spotlights to another layer, then remove them one by one- in order (spot, spot001, spot.002, spot.003). If I tried to delete them all or out of order then instant crash.
However this method does not work on Win 10, 2.77a. I can't delete them in any order. I even moved each spotlight to separate layers and tried deleting each one.
Is there any way to delete these spotlights outside of the user interface?
Thanks,
JohnS
Fix is in master, and will be in next release as well, until then you can use the latest build from our buildbot.
