editmesh intersect (boolean) blender crash #48707
Closed
opened 2016-06-22 09:38:48 +02:00 by Nicola · 10 comments
win 10 x64, nvidia 970GTX
Broken: experimental blender-2.77.0-git.435fa9a-AMD64
Broken: last blender-2.77.0-git.6fbe6eb0-AMD64
Worked: official blender-2.77a-windows64
when tried to do intersect (boolean), blender crash
  1. open file attached (boolean_crash.blend)
  2. edit mode
  3. select cilinder
  4. Ctrl+F --> intersect(boolean)
    crash!
    boolean_crash.blend
**System Information** win 10 x64, nvidia 970GTX **Blender Version** Broken: experimental blender-2.77.0-git.435fa9a-AMD64 Broken: last blender-2.77.0-git.6fbe6eb0-AMD64 Worked: official blender-2.77a-windows64 **Short description of error** when tried to do intersect (boolean), blender crash **Exact steps for others to reproduce the error** 1) open file attached (boolean_crash.blend) 2) edit mode 3) select cilinder 4) Ctrl+F --> intersect(boolean) ... crash! [boolean_crash.blend](https://archive.blender.org/developer/F318185/boolean_crash.blend)
Author
Campbell Barton was assigned by Nicola 2016-06-22 09:38:48 +02:00
Author
Added subscriber: @NicolaFrascati
Added subscriber: @SpectreFirst
I was able to reproduce the crush, but just in case I was also able to successfully perform Boolean Intersection by applying Decimate modifier in Collapse mode with something like 0.8 reduction ratio, applying it and then performing an intersection. Probably this was not a valid solution, but it may work as a workaround.
Added subscriber: @VukGardasevic
I can reproduce the issue too.
Win 7, Blender hash: 1c19940
Selecting the inner cylinder and using Intersect (Boolean) will cause a crash.
What I've noticed that for some reason there is no selection outline on the object DIMA.
Also in my case, adding a Decimate modifier and trying to move the slider from 1.0 down will also crash Blender.
Exporting to obj and importing it again didn't solve the issue.
I can reproduce the issue too. Win 7, Blender hash: 1c19940 Selecting the inner cylinder and using Intersect (Boolean) will cause a crash. What I've noticed that for some reason there is no selection outline on the object DIMA. Also in my case, adding a Decimate modifier and trying to move the slider from 1.0 down will also crash Blender. Exporting to obj and importing it again didn't solve the issue.
Author
for me doesn't work, blender still crash
> In #48707#379024, @SpectreFirst wrote: > I was able to reproduce the crush, but just in case I was also able to successfully perform Boolean Intersection by applying Decimate modifier in Collapse mode with something like 0.8 reduction ratio, applying it and then performing an intersection. Probably this was not a valid solution, but it may work as a workaround. for me doesn't work, blender still crash
Sorry, 0.8 decimation rate indeed doesn't work, however 0.7 and lower worked in my case. Try decreasing decimation rate to 0.7 or less, maybe it will work for you as well that way. By the way, I'm testing this on the latest build 6fbe6eb0 so maybe that is important as well.
This issue was referenced by d9a01a1d04
This issue was referenced by d9a01a1d04f87e46fadbee268cdea2dbf14993fc
5 Participants
Reference: blender/blender#48707
