DXF import incorrect #48854
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#48854
The import of a DXF file is wrong.
All objects are not imported correctly.
Sample of DXF-FIle can be downloaded here:
My e-mail: kay.golze@wipn.de
Thanks for help
Added subscriber: @Kay_Golze
As you can see on the screenshot I tested with the latest version and it still does no import the file correctly. It might be due to your geometry being offset A LOT. When I go into edit mode and look at a vertex. It's not even displayed correctly since the coordinate seems to be large. I only see 10'000/10'000. ... Probably too much for curves in Blender? There is no support to import it directly as a mesh so far since usually curves are enough and this is also how a user can select more transparently how curves should be "rasterized" to a mesh.
Added subscriber: @cnd
Added subscriber: @iss
Changed status from 'Confirmed' to: 'Needs User Info'
@Kay_Golze can you upload files to this site? Links provided are not available.
Or if anybody has file that demonstrate this issue, please provide sample files
Added subscriber: @rjg
No activity for more than a week. As per the tracker policy this issue will be closed, since the required information were not provided.
Thanks again for the report. If the problem persists please open a new report with the requested information.
