STL file not importing correctly #48881
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#48881
Mac OSX 10.11.5
Intel Iris Graphics 6100 1536 MB
Broken: (example: 2.77)
Importing the attached STL file distorts the model completely
Import STL file{F324517}
Added subscriber: @MohammedKhorakiwala
Added subscriber: @mont29
First of all, please avoid submitting a 200Mb file with 1.2M faces as example of bug, it's awfully heavy and pretty much unusable to investigate a bug anyway.
And I see no real issue with that file, seems to import OK to me? What do you expect exactly?
I have imported the STL into both blender and another STL viewer (simplify3D). Simplify3D renders it correctly
Attaching both files.
thanks
Am getting correct results in Blender master here. Please try the latest build from our buildbot, and ensure you do not have an old STL importer somewhere in your user config blender path…
Added subscriber: @ideasman42
Tested, works as expected here too, (it looks like @MohammedKhorakiwala's first image).
Suspect you're importing different files.
{F324981}I am having the same problem with the nightly build. Just to make sure, the attached image is how the file should render.
Added subscribers: @MikeErwin, @brecht
Yeah, that’s what we are getting here, with both current master and official 2.77a release. So either you are not importing correct file or, more likely, you have some older, buggy version of STL addon somewhere in your user
.blender
config folder, which overrides official released version.Or there is some odd bug specific to your platform, could some OSX-based dev test this? @brecht maybe, or @MikeErwin?
Chance that files import as totally different & continuous surface is similar to chance a photo accidentally loads as a different person.
Closing, can re-open if there is some evidence the importer as at fault, this is likely an accident loading the wrong file.
I am pretty sure I have not loaded an incorrect file. Pls reopen the ticket. Is everyone testing this on a Mac or another platform.
