Possible memory allocation problem while rendering #49027
Asset Browser Project (Legacy)
Asset System
Reference: blender/blender#49027
Windows 8 Pro 64bit, AMD FX8350, Nvidia GTX660, 16GB DDR3 RAM
Broken: 2.77 and 2.77a
When rendering 33 minutes worth of 1080p video material with ~150 soft cuts, memory usage constantly rises. Every time the rendered frame marker reaches soft cut - around 80MB gets allocated, then the memory usage hovers around roughly the same level until the next soft cut at which point another ~80MB is allocated. This means that soon enough I get Windows complaining about not enough memory, and with around 12GB of RAM used by Blender - it crashes without even a popup, Just disappears.
I saw it crash even with around 2 GB of RAM still available. I use "Keep UI" option, so the preview window is not engaged when rendering.
Is that kind of behavior in any way normal?
I could upload my .blend file, but it's really just three ~10min/1080p clips that were cut and reordered using ~150 soft cuts. Previewing also allocates a lot of memory, but if I leave Blender idle for a while - it will get deallocated. When I render it only seems to allocate more and more, which is why I suspect there may be a leak somewhere or at least a problem with not releasing memory at an appropriate time.
Workaround
Rendering in shorter parts. Which works, but that's a poor solution.
Added subscriber: @Xupicor
Added subscriber: @Sergey
The memory is coming from the the internal buffers held by FFmpeg descriptors: and each of the strips will have own FFmpeg descriptor. Rest of the buffers in sequencer are limited by the case size. Ideally the FFmpeg descriptors should be covered by the same cache system, but it's quite tricky since it's not possible to know their exact size in memory.
I'll try to make similar cleanup function which closes all inactive FFmpeg descriptors when doing animation rendering. That will match behavior of image sequencer when rendering. Doing that will at least make it possible to render the whole sequence.
This issue was referenced by
1647d89cf1
