The purpose of the task is to discuss how text should be written with properties.
This task is a spit off of T37450
- Type
- Design
Related Objects
Related Objects
- Mentioned Here
- T37450: Tool settings panel location in the UI
Comment Actions
I’d like to know what’s the point of adding another task here, since it’s same as T37450? Further more, UI design tasks tend to have… bad destiny, often drown in 'forum-like' discussion and then abandoned… :/
Anyway, operator redo (i.e. operator's properties) drawing is (mostly) fully automatic, so even if there may be some space for improvement, I don’t think you can aim at your second suggestion (which would not work in case of narrow panel, too).
