dimension in Object mode don't conform to Edit Mode Length measurements #49396
Reference: blender/blender#49396
2.77a
Broken: (example: 2.69.7
4b206af
, see splash screen)Worked: (optional)
I use dimensions to model architecture. works well until this error. I am using metric measurements.
When I make a cube, go to edit mode, switch on Edge Info to show length.
I edit cube and the measurements adjust accurately.
No go to Object mode and delete cube.
Make a new one and adjust the dimensions in object mode.
Go into edit mode and view Edge info again. The edges remain as 2m * 2m * 2m even though you have adjusted it.
Added subscriber: @RakshaanSoogrim
Added subscriber: @sebastian_k
This is not a bug, this is by design (afaik). An object mode transformation does not affect the actual mesh itself, until you apply those transformations with CTRL+A.
If you scale the default cube in object mode and check edge lengths in edit mode, they will still be at the default of 2,2,2. Now if you apply the scale in object mode with CTRL+A(Scale), you can see in edit mode that the lengths are now shown in global scale.
Added subscriber: @mont29
@sebastian_k said pretty much everything, except that you may have 'world' (aka 'real') dimensions by enabling
Global
option on top of Transform panel, in Edit mode…
