CURVE_OT_draw.wait_for_input error #49397
Reference: blender/blender#49397
Blender version: 2.78 (sub 0), branch: RC2, commit date: Sep 17 2015 Linux64bytes
Traceback
RNA_boolean_set: CURVE_OT_draw.wait_for_input not found.
When I start Blender, I have this traceback every time:
I discovered where come the problem:
This file: /usr/share/blender/2.78/scripts/startup/bl_ui/space_view3d.py
space_view3d.py:line 3004: class VIEW3D_MT_edit_gpencil(Menu)
Added subscriber: @DepoixPatrick
This is kinda weird, I can't recreate neither can I see something in
space_view3d.py
that could cause it. Are you compiling Blender by yourself or is this a custom build? Could also be caused by an add-on so please try if using--factory-startup
command line option makes it work.Hi Julian,
I have made what you demand:
patrinux@patrinux-ordi ~ $ blender --factory-startup
AL lib: UpdateDeviceParams: Failed to set 44100hz, got 48000hz instead
No other problem, all is ok.
This is the Thomas Schiex PPA Blender last release.
May be I have a lot of addons and one don't run correctly with Blender 2.78 but I havn't message about an other addon! All is ok.
HERE IS MY STANDART RUN:
[code]
Read new prefs: /home/patrinux/.config/blender/2.78/config/userpref.blend
Registered Code Autocomplete with 13 modules.
Registering simple_property
add_window: added to phytonpath
window: Imported multifiles
adding
Addon mesh_snap_utilities_line registered
Starting
archimesh: added to phytonpath
archimesh: Imported multifiles
object_intersection.py: new version loaded!
[Lux 2016-Sep-20 15:49:28] Attempting to import pylux module from "/home/patrinux/Applications/lux"
[Lux 2016-Sep-20 15:49:29] Pylux module imported successfully
[Lux 2016-Sep-20 15:49:29] Using pylux version 1.6.0 Build 0
[Lux 2016-Sep-20 15:49:29] Attempting to import pyluxcore module from "/home/patrinux/Applications/lux"
[Lux 2016-Sep-20 15:49:30] Pyluxcore module imported successfully
[Lux 2016-Sep-20 15:49:30] Using pyluxcore version 1.6
[Lux 2016-Sep-20 15:49:30] Installed scene post-update handler
Importing modules complete!
module changed on disk: /home/patrinux/.config/blender/2.78/scripts/addons/luxrender/init.py reloading...
04_run_TRANS_START
10_run_EXTRUDE_START
11_run_BEVEL_START
[/code]
(04_run_TRANS_START / 10_run_EXTRUDE_START / 11_run_BEVEL_START) come from NP addons by Okavango but I can remove but the problem stay!
That it's working fine with
--factory-startup
shows that the issue is coming from an add-on. I didn't found any add-on in our repositories that calls theCURVE_OT_draw
(orcurve.draw
in .py) operator, so this must be coming from a 3rd party add-on which we can't handle here in our official tracker.So thanks for the report, but please try to find out which add-on is causing the issue and report it to its authors. (Note that the issue is pretty trivial though)
Added subscriber: @matthieubarbie
Hi,
I know it's old post but from what add-ons this error come from, have the same error from Blender 2.79 last stable version.
Thanks,
Matt
Added subscriber: @VukGardasevic
@matthieubarbie to provide a list of currently enabled add-ons, please attach the
system-info.txt
generated from theHelp> Save System Info
menu by dragging and dropping the whole .txt file into the comment field ( do not paste it's contents directly in the comment field it is difficult to read and breaks up the formatting).For some further reading about how to attach files to reports check the link here:
https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports (under the
Appending files to the report
section)
