AMD OpenCL error - Cycles #49398
6 Participants
Reference: blender/blender#49398
Hello,
on AMD RX 480 I get this error, while the same scene renders perfectly with CUDA on GTX 970.
'Opencl error -61 CL_INVALID_BUFFER_SIZE in CLCreateBuffer'
System:
Blender 2.78RC
Win7 64
Added subscriber: @AlmaTalp
Added subscriber: @bliblubli
Attach an example file which trigger this bug.
In my experience, 16.7.1 crashed in some scenes, but 16.30 on Linux and 16.8.3 on windows never had any problem, so try with one of those.
Thanks, I try to be more specific:
Didn't work in 2.77a (viewport rendering)
Didnt work with 2.78 RCII (viewport rendering)
Didn't work with 2.78 daily build C2D7D47 (viewport rendering)
Unfortunately I cannot share the files because of its content (copyrighted).
It uses 2K and 4K textures and more than 10.000 objects (mostly instanced).
With 16.9.1 viewport rendering does not work, normal render works, but with these problems:
Idea: could this problem be related to some kind of texture number limitations handled differently in viewport render and final render?
I also tried to use split kernel (debug mode) with nVidia + AMD GPU OpenCL mode (together), it resulted error in 'standard' rendering, also half of the image was rendered in progressive mode (OpenCL error -4) Mem object allocation error in clenque NDrangeKernel
Added subscriber: @TomG
I got OpenCl error when rendering with latest build.
AMD 7870, 16.9.1
Does not depend on tile size.
https://dev-files.blender.org/file/data/gn5rchdyrwpxgpg4wesr/PHID-FILE-tydf2b4iqvxbkjdzvx7j/micro3t.JPG
https://developer.blender.org/T49371
Added subscribers: @ThomasDinges, @brecht
We really need a way to reproduce the issue to investigate this. Even if you can't share the original .blend, it is usually possible to investigate what is going on, incrementally removing meshes, materials, textures, etc. until you find more details about what goes wrong specifically and can redo it in a simple .blend.
Even if it requires a complex .blend you can usually replace meshes, materials, textures with dummies to the point that there is nothing of value in the .blend anymore that you can't share.
I spent this afternoon with finding the problem.
I came out with this: when I have about 60 of 4K textures, I got the problem. Same file renders on CUDA.
Important: it affects viewport rendering; tiles-based final render (F12) works.
Another thing: I got blue screen several times instead of error message during the tests.
Is this a card with 4 GB memory? It sounds like an out of memory error that we should be handling more gracefully. If it's a more than 4 GB, we might be reaching limits of 32 bit pointers.
With 60 4k textures memory usage would be:
These are RGB, RGBA and greyscale textures together.
As I wrote it renders on a GTX 970 (3.5 GB memory), I use RX 480 8 GB for OpenCL.
Hello guys, I just tested with 2.78a; still I get this error with another file, only 2 GB texture memory used on RX480, renders well on GTX 970.
Is there any news on this? Thanks.
Use 16.10.4 and try to check motion blur before rendering.
Thanks, it does not work. Viewport rendering just reproduces the same error, it is not related to motion blur; it is related to the number of textures.
Hello Guys, is there any news on this? I downloaded the latest builds and still cannot use my RX480 for viewport rendering.
Try https://builder.blender.org/download/ and wait for new drivers.
Your GPU is running out of memory because the tile size is too large. Unfortunately the tile size for viewport rendering isn't the same as for final renders and isn't controllable from the UI. To change the tile size for viewport rendering you'll have to use python. Set
bpy.data.scenes['Scene'].cycles.debug_tile_size
to the desired size.This kind of thing is handled better in the cycles_split_kernel branch, hopefully we can merge those changes into master soon.
Hello Mai, thanks for the answer.
I have zero knowledge in python; would you please write me down what I exactly should do (and then how to revert back?)
Thanks
UPDATE:
I just made a quick test with the actual version of my 'big scene' on RX480 with the latest nightly build.
It does not render at all. No viewport render, no final render.
For final render I tested with different tilesizes, from 100 x 100 to 1000 x 1000, also progressive rendering.
Same scene renders well with GTX 1070, about 5,5 GB RAM usage (I added some more stuff to my scene since the last test and I bought a new nVidia card as AMD seems to be completely useless for work).
To change the tile size setting for viewport rendering open the python console editor in blender and enter a line such as
bpy.data.scenes['Scene'].cycles.debug_tile_size = 64
, changingScene
and64
as needed.If your scene isn't rendering at all it means you've ran out of GPU memory, the only things to do in that case is to reduce scene complexity or use another device.
Thanks.
'If your scene isn't rendering at all it means you've ran out of GPU memory, the only things to do in that case is to reduce scene complexity or use another device.'
I didn't run out of memory; please take a look on the second part of my former reply. Thanks.
I made some tests with for the viewport.
Changing tilesize makes artifacts on the screen and bad renders.
Differences:
I made a test on a part of the scene.
While default tilesize for viewport render only results the 'openCL error' message and black screen, changing it to 512 or 256 starts fine at the 1st sample, but from the second makes artifacts (random image parts on the screen).
Added subscriber: @Blendify
Please try a build from builder.blender.org/download
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker
we will have to archive the report until the requested information is given.
Sorry, I simply forgot to comment back, it still does not work. (Blender blender-2.78-3ab8895-win64).
