Bmesh Crash on opening a file #49467
Closed
opened 2016-09-27 18:40:23 +02:00 by Aaron Carlisle · 37 comments
Member
Windows 10
Intel HD 4600
Broken: Latest Master
Upon opening https://cloud.blender.org/p/gallery/57e5084f0fcf294119c5055c
you get the following backtrace with a debug build:
    20: BLI_system_backtrace - 0x28B81040
    19: mesh_vert_canon - 0x280E4F00
    18: interp_vmesh - 0x280E5C00
    17: adj_vmesh - 0x280E7DD0
    16: bevel_build_rings - 0x280E8B30
    15: build_vmesh - 0x280EC120
    14: BM_mesh_bevel - 0x280DD510
    13: applyModifier - 0x27FDE120
    12: modwrap_applyModifier - 0x283585B0
    11: mesh_calc_modifiers - 0x28535C80
    10: mesh_build_data - 0x28538310
    9: makeDerivedMesh - 0x2852DE50
    8: BKE_object_handle_data_update - 0x286C4F80
    7: BKE_object_handle_update_ex - 0x284AED00
    6: scene_update_object_func - 0x283B4160
    5: task_scheduler_thread_run - 0x28BDE9B0
    4: sched_get_priority_max - 0x5E2D12FD
    3: sched_get_priority_max - 0x5E2D12FD
    2: sched_get_priority_max - 0x5E2D12FD
    1: BaseThreadInitThunk - 0x824A80E0
    0: RtlUserThreadStart - 0x8378C580
    BLI_assert failed: C:UsersAaronBlenderDevblender-gitblendersourceblenderbmeshtoolsbmesh_bevel.c:2079, mesh_vert_canon(), at '0 <= i && i <= n && 0 <= j && j <= ns && 0 <= k && k <= ns'
Open https://cloud.blender.org/p/gallery/57e5084f0fcf294119c5055c
**System Information** Windows 10 Intel HD 4600 **Blender Version** Broken: Latest Master Worked: (optional) **Short description of error** Upon opening https://cloud.blender.org/p/gallery/57e5084f0fcf294119c5055c you get the following backtrace with a debug build: ``` 20: BLI_system_backtrace - 0x28B81040 19: mesh_vert_canon - 0x280E4F00 18: interp_vmesh - 0x280E5C00 17: adj_vmesh - 0x280E7DD0 16: bevel_build_rings - 0x280E8B30 15: build_vmesh - 0x280EC120 14: BM_mesh_bevel - 0x280DD510 13: applyModifier - 0x27FDE120 12: modwrap_applyModifier - 0x283585B0 11: mesh_calc_modifiers - 0x28535C80 10: mesh_build_data - 0x28538310 9: makeDerivedMesh - 0x2852DE50 8: BKE_object_handle_data_update - 0x286C4F80 7: BKE_object_handle_update_ex - 0x284AED00 6: scene_update_object_func - 0x283B4160 5: task_scheduler_thread_run - 0x28BDE9B0 4: sched_get_priority_max - 0x5E2D12FD 3: sched_get_priority_max - 0x5E2D12FD 2: sched_get_priority_max - 0x5E2D12FD 1: BaseThreadInitThunk - 0x824A80E0 0: RtlUserThreadStart - 0x8378C580 BLI_assert failed: C:UsersAaronBlenderDevblender-gitblendersourceblenderbmeshtoolsbmesh_bevel.c:2079, mesh_vert_canon(), at '0 <= i && i <= n && 0 <= j && j <= ns && 0 <= k && k <= ns' ``` **Exact steps for others to reproduce the error** Open https://cloud.blender.org/p/gallery/57e5084f0fcf294119c5055c
Author
Member
Author
Member
Added subscriber: @Blendify
#50400 was marked as duplicate of this issue
Author
Member
Added subscribers: @mont29, @Sergey
Howard Trickey was assigned by Bastien Montagne 2016-09-28 08:29:54 +02:00
Added subscriber: @howardt
@howardt backtrace seems to point to Bevel issue?
Member
Yes, it is triggering a "shouldn't happen" assert in Bevel. I fixed a similar problem to this recently. Will try to fix this soon.
Author
Member
Any news?
Any news?
Author
Member
Added subscriber: @SteffenD
The Blenderman file is still crashing all the Buildbot builds on opening while official 2.78c can open it. Is this a regression of some sort?
All 2.8 Buildbot builds also crash.
Member
Looking at this again now. For reference, here's a simpler file that causes the assert failure (in mesh_vert_canon): arm_simpler.blend
Looking at this again now. For reference, here's a simpler file that causes the assert failure (in mesh_vert_canon): [arm_simpler.blend](https://archive.blender.org/developer/F598791/arm_simpler.blend)
This issue was referenced by 8be9d68dd4
This issue was referenced by 8be9d68dd42d6831675356bfa0e1bf9274680df3
Member
Member
Fixed this now. Sorry for the long delay. Fixed in master; the 2.8 branch should update in a day or two when merge from 2.78 to 2.8 happens.
Thanks for taking care of this. I just compiled the very latest master and the Blenderman.blend still crashes Blender here.
Member
Hmm. Can you see if the code you compiled includes commit 8be9d68dd4 ? (git log in the blender source directory should show it).
According to the build number in the splashscreen, yes.
And the bmesh_bevel.c source also contains the latest changes.
According to the build number in the splashscreen, yes. And the bmesh_bevel.c source also contains the latest changes.
Author
Member
Changed status from 'Resolved' to: 'Open'
Author
Member
I am going to re-open this then... I can recompile later today and test as long as my render finishes.
Member
I cannot reproduce a crash. Maybe I don't have all the same build settings. Can someone who gets a crash paste a stack backtrace? I am wondering if the crash is still in bevel, or whether it is somewhere else now.
I justed tested it again and found that my own VS2015 builds and the official Buildbot VS2015 builds crash while the VS2013 builds from the Buildbot don't.
Member
Thanks. Do you have a stack backtrace? At any rate, I will try with VS2017 which I have at home and see what happens with that.
No, sorry, no backtrace. I'm not a coder, I'm just glad I can compile Blender myself ;)
Author
Member
@SteffenD to make a debug build on windows just run make 2015 full debug this will give a backtrace after crashing. I would test but my machine is busy rendering still.
@SteffenD to make a debug build on windows just run `make 2015 full debug` this will give a backtrace after crashing. I would test but my machine is busy rendering still.
Member
Added subscriber: @LazyDodo
Member
for what it's worth, i can't repro on win7, with either the buildbot or my own builds....
Added subscriber: @debris
Did you also try the VS2015 builds? The VS2013 builds don't crash for me.
> In #49467#434665, @LazyDodo wrote: > for what it's worth, i can't repro on win7, with either the buildbot or my own builds.... Did you also try the VS2015 builds? The VS2013 builds don't crash for me.
Member
Yes, used a 2015/x64 buildbot from yesterday, and and build (2015/x64/debug) from master today.
Member
After some more testing, i got the buildbot and my local release version to crash, but not my debug build... :(
Member
I could not get it to crash with my vs2017 release or debug builds. I did try the buildbot 2015/x64/release build, and it crashed, but I don't know how to get a symbol file for this so couldn't get a meaningful stack trace. I have a strong suspicion that the problem now is not with bevel, but somewhere else.
Member
after some convincing i had the release build put out a stracktrace
>	blender.exe!carve::geom3d::fitPlane<carve::mesh::detail::list_iter_t<carve::mesh::Edge<3> >,carve::mesh::Face<3>::vector_mapping>(carve::mesh::detail::list_iter_t<carve::mesh::Edge<3> > begin, carve::mesh::detail::list_iter_t<carve::mesh::Edge<3> > end, carve::mesh::Face<3>::vector_mapping adapt, carve::geom::plane<3> & plane) Line 60	C++
 	blender.exe!carve::mesh::Face<3>::recalc() Line 279	C++
 	blender.exe!carve_addMesh(ImportMeshData * import_data, CarveMeshImporter * mesh_importer) Line 640	C++
 	blender.exe!carve_mesh_from_dm(Object * object, DerivedMesh * dm, const DMArrays * dm_arrays) Line 699	C
 	blender.exe!NewBooleanDerivedMesh(DerivedMesh * dm, Object * ob, DerivedMesh * dm_select, Object * ob_select, int int_op_type) Line 758	C
 	blender.exe!applyModifier_carve(ModifierData * md, Object * ob, DerivedMesh * derivedData, ModifierApplyFlag flag) Line 394	C
 	blender.exe!mesh_calc_modifiers(Scene * scene, Object * ob, float[3] * inputVertexCos, const bool useRenderParams, int useDeform, const bool need_mapping, unsigned __int64 dataMask, const int index, const bool useCache, const bool build_shapekey_layers, const bool allow_gpu, DerivedMesh * * r_deform, DerivedMesh * * r_final) Line 2060	C
 	blender.exe!mesh_build_data(Scene * scene, Object * ob, unsigned __int64 dataMask, const bool build_shapekey_layers, const bool need_mapping) Line 2633	C
 	blender.exe!makeDerivedMesh(Scene * scene, Object * ob, BMEditMesh * em, unsigned __int64 dataMask, const bool build_shapekey_layers) Line 2727	C
 	blender.exe!BKE_object_handle_data_update(EvaluationContext * eval_ctx, Scene * scene, Object * ob) Line 204	C
 	blender.exe!BKE_object_handle_update_ex(EvaluationContext * eval_ctx, Scene * scene, Object * ob, RigidBodyWorld * rbw, const bool do_proxy_update) Line 2650	C
 	blender.exe!scene_update_object_func(TaskPool * pool, void * taskdata, int threadid) Line 1517	C
 	blender.exe!task_scheduler_thread_run(void * thread_p) Line 414	C
 	pthreadVC2.dll!000007feeabb627b()	Unknown
 	pthreadVC2.dll!000007feeabb8eb7()	Unknown
 	pthreadVC2.dll!000007feeabb9102()	Unknown
 	[External Code]
after some convincing i had the release build put out a stracktrace ``` > blender.exe!carve::geom3d::fitPlane<carve::mesh::detail::list_iter_t<carve::mesh::Edge<3> >,carve::mesh::Face<3>::vector_mapping>(carve::mesh::detail::list_iter_t<carve::mesh::Edge<3> > begin, carve::mesh::detail::list_iter_t<carve::mesh::Edge<3> > end, carve::mesh::Face<3>::vector_mapping adapt, carve::geom::plane<3> & plane) Line 60 C++ blender.exe!carve::mesh::Face<3>::recalc() Line 279 C++ blender.exe!carve_addMesh(ImportMeshData * import_data, CarveMeshImporter * mesh_importer) Line 640 C++ blender.exe!carve_mesh_from_dm(Object * object, DerivedMesh * dm, const DMArrays * dm_arrays) Line 699 C blender.exe!NewBooleanDerivedMesh(DerivedMesh * dm, Object * ob, DerivedMesh * dm_select, Object * ob_select, int int_op_type) Line 758 C blender.exe!applyModifier_carve(ModifierData * md, Object * ob, DerivedMesh * derivedData, ModifierApplyFlag flag) Line 394 C blender.exe!mesh_calc_modifiers(Scene * scene, Object * ob, float[3] * inputVertexCos, const bool useRenderParams, int useDeform, const bool need_mapping, unsigned __int64 dataMask, const int index, const bool useCache, const bool build_shapekey_layers, const bool allow_gpu, DerivedMesh * * r_deform, DerivedMesh * * r_final) Line 2060 C blender.exe!mesh_build_data(Scene * scene, Object * ob, unsigned __int64 dataMask, const bool build_shapekey_layers, const bool need_mapping) Line 2633 C blender.exe!makeDerivedMesh(Scene * scene, Object * ob, BMEditMesh * em, unsigned __int64 dataMask, const bool build_shapekey_layers) Line 2727 C blender.exe!BKE_object_handle_data_update(EvaluationContext * eval_ctx, Scene * scene, Object * ob) Line 204 C blender.exe!BKE_object_handle_update_ex(EvaluationContext * eval_ctx, Scene * scene, Object * ob, RigidBodyWorld * rbw, const bool do_proxy_update) Line 2650 C blender.exe!scene_update_object_func(TaskPool * pool, void * taskdata, int threadid) Line 1517 C blender.exe!task_scheduler_thread_run(void * thread_p) Line 414 C pthreadVC2.dll!000007feeabb627b() Unknown pthreadVC2.dll!000007feeabb8eb7() Unknown pthreadVC2.dll!000007feeabb9102() Unknown [External Code] ```
@LazyDodo, do you mind testing this patch P479: Snippet for #49467
diff --git a/source/blender/modifiers/intern/MOD_boolean.c b/source/blender/modifiers/intern/MOD_boolean.c
index f86d8b99f3c..3a0b19fac87 100644
--- a/source/blender/modifiers/intern/MOD_boolean.c
+++ b/source/blender/modifiers/intern/MOD_boolean.c
@@ -368,8 +368,17 @@ static DerivedMesh *applyModifier_carve(
 		return derivedData;
 	dm = get_dm_for_modifier(bmd->object, flag);
+	if (!DM_is_valid(derivedData)) {
+		printf("Invalid DerivedData!\n");
+		return derivedData;
 	if (dm) {
+		if (!DM_is_valid(dm)) {
+			printf("Invalid dm!\n");
 		DerivedMesh *result;
 		/* when one of objects is empty (has got no faces) we could speed up
and see if both DM are valid?
@LazyDodo, do you mind testing this patch [P479: Snippet for #49467](https://archive.blender.org/developer/P479.txt) ``` diff --git a/source/blender/modifiers/intern/MOD_boolean.c b/source/blender/modifiers/intern/MOD_boolean.c index f86d8b99f3c..3a0b19fac87 100644 --- a/source/blender/modifiers/intern/MOD_boolean.c +++ b/source/blender/modifiers/intern/MOD_boolean.c @@ -368,8 +368,17 @@ static DerivedMesh *applyModifier_carve( return derivedData; dm = get_dm_for_modifier(bmd->object, flag); + if (!DM_is_valid(derivedData)) { + printf("Invalid DerivedData!\n"); + return derivedData; + } if (dm) { + if (!DM_is_valid(dm)) { + printf("Invalid dm!\n"); + return derivedData; + } + DerivedMesh *result; /* when one of objects is empty (has got no faces) we could speed up ``` and see if both DM are valid?
Closed as duplicate of #51540
Added subscriber: @ideasman42
Carve has known crashes and isn't maintained, one reason bmesh boolean was developed.
9 Participants
Reference: blender/blender#49467
