2.78 Wrong texture scaling in material viewport #49534
5 Participants
Reference: blender/blender#49534
Windows 10 Home, version 1607, Build 14393.222
Intel Core i7-3770K, 3.5GHz, 8GB RAM
Geforce Titan
Broken: 2.78
Worked: 2.77a and 2.74
When selecting the material display in the viewport, part of the textures are corrupted. The texture of the bridge in the lower center seems to be wrongly scaled. The castle above seems to use the textured viewport instead and shows the texture, which was selected lastly in the node editor. The textures of the rocks in the lower left and right seem to be ok. This worked fine with 2.77a. I have loaded the file on my notebook, which still uses 2.74. Everything's fine as well. The rendered viewport is ok with 2.78:
As blender.exe was not installed with the msi file and I needed to perform a repair install to get an executable, I have tried the zip file instead. In both cases the result is the same.
The original file is about 500MB of size with packed textures. When I tried to remove stuff to create a minimum size file (which appeared to be quite easy as the scene includes three differently deep "layers" of objects), the rendered view becomes a noisy grey image without details.
The materials viewport still shows the camera image. This happens as well when I render the image with F12. This is independent of rendering with CPU or GPU. And also this happens when I restart Blender.
The "smallest" file with the grey result is 400MB. I am not sure if I should upload it due to its size (and my internet connection). Please direct.
Load the file and click the material viewport display in the 3D view.
Added subscriber: @HaJotCe
Added subscriber: @brecht
Is it possible to select one of the objects with wrong texture display, select invert, and then delete everything else? Or create a new .blend and append just one of the objects with the problem?
What the rendered view looks like doesn't really matter, if the textures shows ok in 2.77a but not in 2.78 we can debug it.
Here is the file, condensed to 21Meg:bridgeBack-packed.blend
I have appended the bridge object to a new file. All textures are packed. I'm wondering, why the face count is 0:
Added subscribers: @dfelinto, @Sergey
Can't confirm there's 0 faces, but shading indeed seems weird in the viewport. From quick check seems partitioning is done done wrong for materials or something like that.
Maybe @dfelinto will be interested in having a look here? :)
I reproduced the bug in a much simpler file: uv-material.blend - this will show greenish in
2.77
and red in2.78
.Basically the issue (on material mode at least) is that the UV being used in
2.78
is different than the one in2.77
. If you change which UV is the active/selected in2.78
you will see the result changing.Actually, the issue is that you are using the
Attribute
node instead of theUV Map
node to get the UVs.And something on top of that, if you take my last sample file, and remove the NormalMap you still see the bug, until you save and re-open the file.
This issue was referenced by
625b504b23
