Blender 2.78 Grease Pencil - pen pressure problem (Yiynova Tablet) #49628
5 Participants
Reference: blender/blender#49628
Windows8.1 - GeForce GT750M - Tablet: Yiynova MPV20U+RH
Broken: 2.78
When drawing with Grease Pencil the last bits of many lines get very thick as if I were drawing with full pressure.
The pressure sensitivity itself works just fine, up until the last bit of the line. It works without problems in all other graphic apps I use.
It might be some kind of problem with the Yiynova drivers. With my old Wacom Bamboo I never had such issues.
Demonstration of the problem: https://www.youtube.com/watch?v=Y35yPFysq_w
try to draw with Grease Pencil using a Yiynova tablet
Added subscriber: @KonstantinBukow
Added subscriber: @JoshuaLeung
In general, it's hard to reproduce or fix issues which only occur on specific/uncommon hardware that we don't have access to ourselves, so unless something changed here recently, it's likely to be quite hard to find a fix for this.
To help us figure out where the problem might be, could you check on a few things:
Hey Joshua,
I made some tests:
I tried with 2.73a and it seems to work fine in sculpt mode but the Grease Pencil produces the same errors
In 2.78 the sculpt mode produces the same error that GP does. many of the lines I draw end with the maximum size/strength of the brush.
hope that helps. If you like I can do another video to show the results
Added subscriber: @mont29
This sounds like a driver issue to me (driver sending bad 'last point' width info…).
But in any case, besides usual tips to try older/newer drivers if possible, we won’t be able to do anything unless we find a dev with similar hardware able to reproduce the issue… So will archive the report for now.
Hello,
I am super-excited about all the awesome work on 2.8 and its recent inclusion of the grease pencil branch. I am already having lots of fun with 2.8 (I also already got some actual work done with it) but unfortunately this bug has carried over and is still so annoying that the grease pencil is basicly useless with my current set-up. I have pen pressure working in Photoshop, Illustrator, Artrage, Krita etc. - so I am pretty confident that blender is causing the issue. I am not really a developer, but I´d like to help you with fixing this - I also could imagine that lots of blender users would love to successfully use their non-wacom tablets with blender.
Is there any way that I can output the pen-input values blender is recieving?
I thought about logging the grease pencil input to maybe get a grasp of whats happening behind the scenes.
Added subscriber: @YAFU
Hi.
I'm not a developer, but here are a couple of scenes to check if the problem also occurs in other modes (as Joshua suggested):
TexturePaint.blend
CurveDraw.blend
Also while trying to find a solution for windows problem, you could try in some modern Linux distribution, apparently some Yiynova tablets are supported by default by generic driver:
https://digimend.github.io/tablets/
Edit:
Sorry, now I see that apparently this is not a simple desktop graphic tablet. I'm not sure that Linux can be installed on it.
@KonstantinBukow Short of modifying the grease pencil code (see
gpencil_draw_modal()
in eithergpencil_paint.c
orannotate_paint.c
) to check what pressure values Blender is getting/using, you could also try running Blender with the--debug-events
flag.Checking the code quickly, a possible cause is that on the pen-up (end of stroke) event, the tablet may not be sending "tablet data" along with the event, causing Blender to think that this came from a mouse instead, causing it to choose the default pressure of 1.0 (i.e. big ugly blotches at the end of strokes). See the
if (event->tablet_data)
checks ingpencil_draw_apply_event()
.Added subscriber: @pablovazquez
Can confirm stylus pressure not working in Blender (in general, not only GP). I'm using a Wacom Intuos 5 Touch under Ubuntu 17.10.
@JoshuaLeung I checked the code that you mentioned and indeed the
doesn't go through so it defaults to 1.0f.Running Blender with --debug-events yields stylus input as what it seems regular mouse input:
Removing the if statement of course crashes because it seems
event->tablet_data
is empty :(Tried the same in 2.79b and 2.78c to no avail, no pressure sensitivity there either. It works on other applications (Krita, GIMP, and the "Test Settings" tool in the Wacom preferences in GNOME 3).
@YAFU the device is basicly a standard pen digitizer display, so there´s no OS running on the device itself. It´s basicly the poor-man´s cintique from china. considering the price difference it´s a really neat piece of hardware and it would be a shame if it was unusable with GP. I will check out how it performs in the other modes!
@JoshuaLeung thanks so much for the help! I will make some further experiments and let you know what happened!
@venomgfx would it be possible to change the code in a way that the pressure value defaults to 0f if no tablet data is recieved, or would that mess up the mouse input?
Again thanks everybody for your help! This is very much appreciated and I will try my best to help!
Pressure 0f means a stroke size of 0, so you won't see anything.
@venomgfx yeah seeing nothing in this situation is exactly what I need! :) Obviously the pressure data is recieved correctly during the brush stroke, since I can draw perfectly fine up to the moment I lift the pen (this is where it creates these ugly full-pressure dots). Joshua´s theory was that the pen-up event of my tablet driver doesn´t include any pressure information (where it should be 0), so I thought if I have a default pen pressure of 0f everything should be fine, because as soon as I start drawing the value should change to something positive. Please let me know if I my logic is wrong. I got my very limited knowledge about input managment by building a few game prototypes over the last year, so this is how I would try to hack the problem if it was occuring in one of my games
@JoshuaLeung so I started blender with the --log-events flag and with that I could confirm your theory about the missing pressure information on the release event. It´s really weird that it just happens so randomly. I made another short video demonstrating whats happening with the console open: https://youtu.be/LRnzfMrVwmU
If possible I´d try to set the pressure value to 0f on every release-event. At least in my head it sounds like a plausible solution :)
Thanks a lot for taking your time everybody!
@JoshuaLeung @venomgfx Guys thank you so much for the help! Surprisingly everything was exactly like I expected: Setting the default value to 0f solves the problem for the pen input but disables the possibility to draw with the mouse. I will now go to try to find the solution in the release event. I AM SO HAPPY!!!! XD demonstration: https://youtu.be/xkWECtX-ORs
