FirePro GPU Render No Longer Working #49874
Reference: blender/blender#49874
Win 7 64bit
AMD FirePro Settings - Overview:
FirePro Software Version - 16.2
FirePro Software Edition - 16
Graphics Chipset - AMD FirePro W5000
Memory Size - 2048 MB
Memory Type - GDDR5
Core Clock - 825 MHz
Windows Version - Windows 7 (Service Pack 1)
System Memory - 8 GB
CPU Type - Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
AMD FirePro Settings - Software:
FirePro Settings Version - 2016.0709.311.3902
Driver Packaging Version - 15.301.2601.1002-160708a-304955C-Retail_End_User
Provider - Advanced Micro Devices, Inc.
2D Driver Version - 8.1.1.1533
Direct3D® Version - 9.14.10.1171
OpenGL® Version - 6.14.10.13423
OpenCL™ Version - 2.0.4.0
AMD Mantle Version - Not Available
AMD Mantle API Version - Not Available
AMD Audio Driver Version - 7.12.0.7723
Broken: 2.78a
e8299c8
Worked: 2.77a
Blender no longer working with FirePro GPU Rendering. It worked well with 2.77a and I wanted to see the improvements to OpenCL. I tried going back but it informs me that a later version is installed and exits.
I tried using each Pitcain in the settings and the Pitcain x2 option, but all error.
Open blender, change to cycles, select GPU compute, hit F12. Error reported in console:
Read new prefs: C:\Users\nellypledge\AppData\Roaming\Blender Foundation\Blender
2.78\config\userpref.blend
found bundled python: C:\Program Files\Blender Foundation\Blender\2.78\python
trying to save userpref at C:\Users\nellypledge\AppData\Roaming\Blender Foundati
on\Blender\2.78\config\userpref.blend ok
<!> event has invalid window
Device init success
Device init success
Compiling base_kernel OpenCL kernel ...
Build flags: -D__NODES_MAX_GROUP__=0 -D__NODES_FEATURES__=0 -D__MAX_CLOSURE__=1
NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ -D__NO_PATCH_EVAL__
OpenCL kernel build output:
"C:\Program Files\Blender Foundation\Blender\2.78\scripts\addons\cycles\kernel\k
ernels/opencl../../kernel_projection.h", line 238: error:
1 error detected in the compilation of "C:\Users\NELLYP~1\AppData\Local\Temp\OCL
9812T2.cl".
Frontend phase failed compilation.
OpenCL build failed: errors in console
Build error: CL_BUILD_PROGRAM_FAILURE
Error: OpenCL build failed: errors in console
Added subscriber: @nranthony
#49986 was marked as duplicate of this issue
#50012 was marked as duplicate of this issue
#49890 was marked as duplicate of this issue
Added subscriber: @LukasStockner
This should be fixed with
5aa6a2ec06
. In case it isn't, please reopen the report.Added subscribers: @Slow-Bot, @VukGardasevic
Thanks, I think I'm working again.
I made the changes to kernel_projection.h as suggested and it now appears to work. I didn't change anything in kernel_shader.h as the function defined on line 237, shader_setup_from_sample, is different in many ways.
Also, I couldn't find anything in the path mentioned, but searched and found them in C:\Program Files\Blender Foundation\Blender\2.78\scripts\addons\cycles\kernel
Thanks
Neil
Added subscribers: @lightdefender, @brecht
Added subscribers: @SmartySmart702, @mont29, @Almisuifre
