System Info Attached
Broken: 2.77a, 2.78a
Three crash reports attached.
Saving the file without changing the name causes a segfault - this is repeatable on my system with the attached .blend most of the time, however it does not occur with other files (for example I can save over the startup file without issue)
I have older versions of this file which do not seem to cause the issue, however after reverting to one and working for a while the issue seems to reappear.
The mesh and armature are created with ManuelBastioniLab.
Attempt to save the .blend without changing the name.
