Nothing is happening when I upload a collada file #50198
6 Participants
Reference: blender/blender#50198
Windows 10 Pro version 1607, 64 bit operating system
2.78 a
When I go to file > import > collada, it brings me to the page where I can choose my file. When I select the file and hit "Import COLLADA", nothing happens. It brings me back to the main screen, but the file is not imported. There is seemingly no error.hard_cover.DAE
I have uploaded the file that I am trying to import. Am I doing something wrong?
Thank you
Added subscriber: @KristenEKelly
Added subscribers: @GaiaClary, @mont29
Sounds like collada file is not valid, in console I’m getting those errors:
@GaiaClary will let you check whether this is indeed invalid file, or bug in collada importer ;)
Added subscriber: @VukGardasevic
I did some comparison with a file exported from MakeHuman.
The main difference is that like the error message says the texture map definition is missing from the
Material #23.
Also, does including the # in the material name is valid as it is used for referencing ?
The texture path was hardcoded into the file itself and not relative.
@KristenEKelly what is the program that created the DAE file? Is it 3D Max maybe?
Also this modified DAE file should import fine (apart from the missing image with path to a location on C: drive).
hard_cover_test.DAE
As far as i can see the Collada Importer rejects the import because of the wrong material name syntax.
What we should do in such a case:
I am not sure about the graceful import, but i look into that.
Thank you for your reply!
@VukGardasevic I am actually not exactly sure what program the file was created in...The company I work for hired someone on Upwork to create the file for us, but we have to edit the dimensions of the file for our customers. I read that Blender was the best program to work with. I will try to load the modified Dae, thank you!
@VukGardasevic I was able to import the modified Dae file, thank you! I am getting the same error with this file, which I'm assuming is the same issue{F417524} They were created by the same 3D. Any help you have with this 2nd file would be greatly appreciated!
Thank you again!
@GaiaClary Can you possibly help with one more collada file? The other developer was able to pinpoint the problem with my file so that I was able to import it into blender. Any assistance would be greatly appreciated so that I can use the blender application for my other collada file.
soft_cover.DAE
Thank you!
Added subscriber: @dfelinto
It's not up to Blender to open corrupt collada files. @GaiaClary maybe close this as TODO and write up the fallback collada import in the Collada todo page?
I will look into this shortly.
This issue was referenced by
22faf66c8b
4bd72586aa
Hi, Kristen;
Thanks for reporting. At the end i found the problem was in the way how the importer handles errors. Your files should now import with warnings about missing images.
