Imported FBX Animation (coming from Unreal Engine) makes Blender switch to 25 FPS #50399
Reference: blender/blender#50399
Windows 7 / NVidia GeForce GTX 960
Broken: 2.87a
e8299c8
I created a cube with 2 bones and a simple 200 frames-animation in 3Ds Max and exported the result as FBX. I can import this FBX into Blender and Unreal and everything is fine. BUT when I export this cube (+animation) again out of Unreal into a new FBX and import this new file into Blender, the dimensions settings are forced to 25 FPS even if I set 30 FPS before.
Note: This bug was also reported in the Unreal Engine Forum but I'm not sure on which side the bug is created - Blender or Unreal.
https://answers.unrealengine.com/questions/544386/unreal-animation-export-makes-blender-switch-to-25.html
Added subscriber: @BlenderSimon
Added subscriber: @mont29
I’d expect that to be Unreal issue, they most likely do not write correctly the FPS settings (would be
TimeMode
and/orCustomFrameRate
settings inGlobalSettings
node).I thought that too but in this case 3Ds Max shouldn't be able to read the correct 30 FPS of that file which it does. :(
OK, so checked the files, Unreal one has
TimeMode
set to 0, akaeDEFAULT_MODE
, aka 'use the frame rate you want', so Blender and 3DSMax are free to do what they want here am afraid (at least official docs says nothing special about this mode).3DS one has
TimeMode
set to 6, akaeFRAMES3030
(aka black & white NTSC), which we can interpret correctly.So definitively sounds like UE4 bug to me, when exporting animation you should always set an explicit framerate! Thanks for the report anyway.
Added subscriber: @ZalitZ
In case you really need to import from UE4 with the correct framerate , I found a dirty workaround.
Export your FBX from UE4 in ASCII format. Open the file in a text editor and search for TimeMode (In the Global Settings category) :
From there, change the 0 at the end to whatever number suits your needs, see the official docs to know which number to use. Save your file.
The number corresponds to the list and starts at 0. I needed to import a 60fps fbx so I replaced the 0 with a 3.
But Blender doesn't support ASCII so you need to convert your fbx into a binary one. Luckily, Autodesk provides a free converter there. I had to open Firefox to open the link for some reason. Now install the converter and convert your modified ASCII to a binary fbx.
Import in Blender and it should work !
I really hope it will be fixed one day. I didn't try the Unreal to Blender Addon from this video from Unreal Official Youtube channel. It could work .
