Cycles baking time estimate and progress bar doesn't work / progress when baking with high samples. #50687
Closed
opened 2017-02-14 19:53:07 +01:00 by Goordon · 7 comments
Linux Mint 18.1 Serena
Nvidia GTX 1080 Standard Clock
i7 6700K Standard Clock
16GB Ram
system-info.txt
Broken: (2.78b Linux Mint 18.1)
Worked: (2.78b Windows 10)
Worked: (2.78 no a or b - just the initial Release - http:*download.blender.org/release/Blender2.78/blender-2.78-linux-glibc219-x86_64.tar.bz2 -, Linux Mint 18.1)
When baking a texture in Cycles with a high amount of samples or large texture-resolution the time left estimate is a huge negative number and the progress-bar doesn't move
BugReport.blend
Open the attached .blend file, select the Plane object and click "Bake". Check the estimated time left by hovering over the progress bar. Also notice how the progress-bar is not progressing. Happens on both CPU and GPU.
**System Information** Linux Mint 18.1 Serena Nvidia GTX 1080 Standard Clock i7 6700K Standard Clock 16GB Ram [system-info.txt](https://archive.blender.org/developer/F485422/system-info.txt) **Blender Version** Broken: (2.78b Linux Mint 18.1) Worked: (2.78b Windows 10) Worked: (2.78 no a or b - just the initial Release - [http:*download.blender.org/release/Blender2.78/blender-2.78-linux-glibc219-x86_64.tar.bz2 ](http:*download.blender.org/release/Blender2.78/blender-2.78-linux-glibc219-x86_64.tar.bz2) -, Linux Mint 18.1) **Short description of error** ![screenshot.png](https://archive.blender.org/developer/F485423/screenshot.png) When baking a texture in Cycles with a high amount of samples or large texture-resolution the time left estimate is a huge negative number and the progress-bar doesn't move **Exact steps for others to reproduce the error** [BugReport.blend](https://archive.blender.org/developer/F485421/BugReport.blend) Open the attached .blend file, select the Plane object and click "Bake". Check the estimated time left by hovering over the progress bar. Also notice how the progress-bar is not progressing. Happens on both CPU and GPU.
Author
Author
Added subscriber: @Goordon
This issue was referenced by blender/cycles@8cf0e6d966
This issue was referenced by blender/cycles@8cf0e6d9666b7e5df7b273c381ff5d4c9d912418
This issue was referenced by 306acb7dda
This issue was referenced by 306acb7ddaa541fe8316c1c12eb6abd004876a01
Added subscriber: @Gard
Removed subscriber: @Gard
Reference: blender/blender#50687
