Strange behaviour when selecting geometry in python and using that geometry to do mesh operations via user interface #50771
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#50771
OSX iMac 5k
2.78b
You need to do a 'physical' object mode toggle instead of programming that toggle to do mesh operations on python selected faces/edges/polys
press I (for inset)
Should work as expected
press F6 to tweak
Observe Erratic behaviour: Nothing gets updated!
Observation: before pressing I, toggle Object/Edit mode by hand (TAB) and then use Inset will work
Toggling by python instead of by hand won't make it work..
I've noticed this problem when working on a script which does the following:
Enter Edit mode, and as an example set Face Selection Mode.
Select faces
Put those selected faces.indices in a buffer
Select other faces
Do a boolean operation on those two selections
Works as expected..
However, with those selected faces, trying a mesh operation like inset or bevel will work at first, but when pressing F6 afterwards, Blender will instantly revert back to it's last 'official' selection..
A little bit different in result, but similar.. hope this is the same bug.
The script needs to toggle back and forth between EDIT/OBJECT mode, thus creating a similar situation as in the bug report..
To prevent F6 from failing, I have to toggle MANUALLY between EDIT/OBJECT mode to get it to accept the complete selection. Python toggling the mode won't help..
Hope it all makes sense,
Regards,
Roel
Added subscriber: @kostex
Added subscriber: @dfelinto
It's not a bug, you need to push undo via Python:
https://docs.blender.org/api/blender_python_api_master/bpy.ops.ed.html?highlight=undo#bpy.ops.ed.undo_push
It's related to blender/blender#38676
In other words, if you do bpy.ops.ed.undo_push() before doing 'i', it works fine. Closing the report for now. Let me know if the problem persist, so I can re-open it.
