FBX Export broken +++ all colors will be white #50915
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#50915
Latest Win 10 / GTX 880M with latest driver
Broken: 2.78c
Worked: one of the former versions (can't say which)
FBX exports material colors to a white color only
Result: all colors are white
Same result in MODO (The Foundry)
Added subscriber: @Renderbicks
Added subscriber: @VukGardasevic
There is no attached .blend file in the report.
For some further reading about how to attach files to reports check the link here:
https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports
Marking as Incomplete until the requested data is provided.
visualldconfig.zip
Added subscriber: @mont29
Thanks for the test file.
Tested the file with exporting it from Blender as FBX and re-importing it back in Blender with build 76015f9 and there, indeed, color is white for the materials.
However, i don't know if it is possible to have them stored - is it a current limitation of the implementation or the standard, or something that should work in certain cases.
@mont29 if you have time can you look into this? Thanks in advance.
Thanks for the report, but nodal materials (hence Cycles ones) are not supported by basic shading system of FBX format. You need to use 'old' BI materials.
