Normal map with bold relief causes black artifacts with Glossy BSDF shader #51008
Reference: blender/blender#51008
Windows 10 x64 home, Nvidia GTX 1070 with latest WHQL drivers.
2.78c
Some kind of normal maps - like folded foil or crumpled sheet of metal - produces black artifacts in their folds with "Glossy BSDF" shader node (no problems with
"Diffuse BSDF" though). That start to happen then "Strength" parameter of "Normal map" node is high enough - at low values (~"0.5" and lower) those black artifacts disappears.
Example screenshot .
[Bugreports] Black artifacts on normal map.blend
Added subscriber: @Lex4art
Added subscriber: @LukasStockner
This is the same problem as in #49921 - the normal mapping changes the surface normal, so the reflected ray would go inside the actual geometry, which isn't really possible.
In this case, the way to get around this problem is to use microdisplacement with a displacement map instead of normal maps.
Sorry for the non-answer, but this isn't really something we can fix.
Added subscriber: @MikiProxima
I also have struggled with this kind of artifacts and found a simple trick how to avoid them. Basically you can calculate a dot product between normal and incoming vector and attenuate the normal map where it could cause problems viz https://blenderartists.org/forum/showthread.php?382497-Black-material-artifacts-on-flat-angle-surface-areas
Thanks, that will do the job for me - smart solution ).
Added subscriber: @lsscpp
I found a weird shading bug for wide surfaces. The black reflections come back in this file: http://pasteall.org/blend/index.php?id=46239
