Addon: Set object origin from selected in edit mode #51009
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#51009
Small script to set the origin of an object directly in edit mode, without the user have to place manually 3DCursor in editmode, switch to object mode, and set origin-to-cursor.
Code retrieved from https://blenderartists.org/forum/showthread.php?237785-Set-origin-to-selected and mixed with other users sparse code from thread comments. Thanks to original coder(s). Original attribution is in "author" field.
It use Alt-C shortcut or can be called with Spacebar>"Set Origin to Selected"
Generate an error on unregister (does not clean the shortcut?), but it do his job very well, so unregister is not mandatory :D
Very useful and fast.
object_origin_to_selection_revamp.py
Added subscriber: @blend-it
Added subscriber: @BrendonMurphy
hi, I'll have a look at your code, keep in mind this is already in both the dynamic spacebar menu & the new Origin Pie in viewport pies & there's several advanced addons dealing with origin externally.
Hi and thanks for your attention :)
I think that standard blender management of object origin is too complicated and slow.
I didn't know your addons, very interesting for more complex tasks.
I searched over the net something of extra-fast and easy to place the origin (also with direct shortcut), and I've aggregated some parts of code in this little script (90% not mine!).
It's so strange users must use an addon to do a so basic change; perhaps it was better if something similar was directly included in plain blender without any addon: the current way to place origin is totally unfriendly and "baroque" :D
hi, I fully understand your points, which is why i have this much needed functinality in the spacebar menu addon & pie menu new in 2,79 "Origin Pies:.
Hopefully in 2,8 we will have built in method for this basic required function.
closing as resolved.
Other solutions are not light and fast as this one, but ok.
