bpy.ops.action.new() does nothing when invoked from script #51011
Reference: blender/blender#51011
Win 8.1, GTX1070
Broken: 2.78c
e92f235283
bpy.ops.action.new() does nothing when invoked from a script. Maybe you're not supposed to but then why is it listed in the API?
Create some object. Create an action in the action editor. Open a text editor and write
and click run script. Nothing happens. I would expect the same thing happening that happens when you click the add action button in the UI: a new action is created with identical keyframes and then selected in the action editor list automatically.
edit: changed from Addons to BF Blender tag.
Added subscriber: @cyaoeu
Added subscriber: @BrendonMurphy
hi,
to test:
On default cube, insert keyfame 0, move timeline to 100, scale & move the cube, insert keyframe.
run this:
A new action is created as expected.
Closing as invalid.
What? You created the action when inserting the keyframes...
But I guess I can be more clear about what's wrong.
hi, ok, getting it now.
I think probably this is a more a python support issue, I see now that indeed you are correct & your code does fail.
have you looked at blender stackexchange for similar questions?
it would seem to be that to do this by py you need to set a keyframe first?
also unsure if contexts for this operator are correct or need to be set.
I saw in the Blenderartist forums that someone had the same problem, the advice that was given was to "not use the operator", which seems like a bad workaround if you really want the same behavior. I really like the + button operator, it creates a new action with the same name+.001, selects it in the action editor automatically and even copies all of the keyframes from the previous animation. Basically great for when you're making for example looping variations. The only problem with it is that it doesn't work in scripts right now.
I think the context for the operator should be correct, if you remove the bpy.context.area.type = 'DOPESHEET_EDITOR'
bpy.context.space_data.mode = 'ACTION' stuff you get a polling error. But if you execute those commands you don't get an error. To me this means that it should be correct. Nothing happens though which is a bit strange. If you're not supposed to be able to use the operator in scripts I would expect an error explaining why it can't be used. But if it's really a bug that it doesn't do anything right now I would be happy if it could be fixed.
reopening for more investigation
Added subscriber: @mano-wii
Analyzing the
bpy.ops.action.new
's code, I could see that it only works when it is called from a button.This is because it reads the button context and gets the current action through it.
This is a bad assumption, as this operator is totally useless if called in python.
This issue was referenced by
24ebed4d84
