Sapling tree gen error when objects have åäö in the name #51157
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#51157
Windows 10 Home (Swedish language)
GTX 1070
Broken: 2.78c
Worked: 2.77a (on windows 7)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x85 in position 3: invalid start byte
Start blender. Rename default cube to Låda (any name with lowercase åäö will do). User preferences->Addons-> Add Curve: Sapling Tree Gen.
Shift-A->Curve->Sapling Tree Gen.
blender_sapling_error.blend
Added subscriber: @BlenderAmateur
I was able to replicate this, but inconsistently. Can anyone confirm if this is a blender issue or something addons need to handle themselves. If it's the addon then how do I fix it?, because I do not know what's causing this.
Added subscriber: @mont29
Added subscriber: @bliblubli
@Abpy Blender and Python both can handle UTF-8 correctly. But maybe see https://developer.blender.org/T50926, because python on windows by default doesn't use UTF-8 encoding everywhere.
Added subscriber: @BrendonMurphy
hi, I was under the impression that py does not handle special text characters.
possibly we could add the unicode block to the addon?
https://wiki.blender.org/index.php/Dev:Doc/Code_Style says to avoid special characters
Added subscriber: @Blendify
@BrendonMurphy that is in the code, not as a user.
@Blendify, I'll seek clarify adding priority normal,
I have a workaround that uses base64 to pass the string through the addon. It lets you choose the objects but still doesn't show the correct object name in the menu.
hi testing this (following exact reproduce from op) I was able to get the error using the presets & also in ui.
adding
to the file header (line1) in init.py & utils.py
& I cannot reproduce the issue
will commit fix soon
This issue was referenced by
ba6a119db2
awesome, I didn't know file encodings could cause things like this. Its a lot better than my ugly workaround. thanks.
