inconsistency between the manual and latest UI for stroke edit mode access #51160
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
2 Participants
Reference: blender/blender-manual#51160
I've found some inconsistency between the manual and latest UI, details as below:
The stroke edit mode page says:
Screenshot is pasted here: (http://pasteall.org/pic/index.php?id=114499)
But the "
Enable Editing
" button is no longer available in Grease Pencel panel for Blender 2.78.So, I want to know if it will be added back in later version. If the answer is "No", I think the manual should be corrected to avoid misleading users.
Added subscriber: @nge
Added subscriber: @Tobias
Actually this button is shown in the 2D editors (UV-Image editor, Node editor, etc.), once a stroke is drawn.
So this just has to be clarified as additional info in brackets.
Got it! I've modified the manual to be:
