Lens Distortion node Error #51271
2 Participants
Reference: blender/blender#51271
Tested on:
Windows Vista 32bit
Linux Mint 64bit
Windows 8 64bit
Also reproduced by two others in IRC #Blender
Broken: 2.77, 2.78, buildbot 2.78.4
Worked: 2.76b
Lines along edges of image
Open default scene, render, in compositing add Lens Distortion node.
Along bottom edge as well at 100% render size
Dispersion Error.blend
Believe the cause to be Dispersion as changing setting from 0.0000001 through 0.0000009 changes shape and color of lines.
Also get lines along render tile edges randomly but unable reproduce consistantly.
Added subscriber: @Royce
buildbot hash value in report (now removed) caused Mention of fix with same value in name, not sure how to remove/unmention.
Added subscriber: @Sergey
This isn't really a bug. It is caused by some numerical changes and extra clamping applied after 2.76. Those fixes were needed to fix other artifacts in compositor.
This black line is coming from the node implementation itself. If you increase distortion to higher values (~0.2) then you'll see the black outline around the image. It is coming from the malformed handling of alpha and anti-aliasing on edges with the particular lens distortion node.
So thanks for the report, but it's just a limitation of math used in this node..
Alright, and to double check .
Having artifacts with dispersion in use, set to a value greater than defualt 0, I understand.
The problem is that the lines are there with the default 0 value, at which it shouldn't effect the image.
I'll have to find a work around to add Jitter noise to images then.
Thanks for information.
