bpy.ops.select_pattern() returns {FINISHED} even if object wasn't successfully selected #51310
2 Participants
Reference: blender/blender#51310
Win8.1, GTX1070
Broken:2.78c
e92f235283
bpy.ops.select_pattern() returns {FINISHED} even if object wasn't successfully selected. For example if you're trying to select something on a layer that isn't visible. I use this in my export script. I've got the mesh and rig on different layers. Sometimes I forget to show the layer with the rig on and export only the mesh. When this is imported into UE4 using reimport strange things happen.
I think this operator should return an error if nothing was actually selected, in case for example you're trying to select something not visible. Or automatically showing the layer the object was on if nothing was selected at first.
bpy.ops.object.select_pattern(pattern="Cube")
in python console (assuming name of the cube was Cube).
Expected: error when trying to select unselectable object.
Added subscriber: @cyaoeu
Added subscriber: @Sergey
FINISHED means that operator execution finished, it does not denote anything whether operator changed something or not. So there is no bug here, since the operator did not fail or anything, it just didn't find anything selectable.
I think it should fail (raise an error) if nothing was selected. If you expected something to be selected (which you probably do when running an operator called select_pattern) and nothing was selected it's an undesirable result.
I'm using select_pattern in my export scripts and if select_pattern didn't do anything in my script for some reason strange things happen. For example I was trying to select my rig, but it was on a hidden layer, so now I'm exporting my character without a rig. Thankfully the game engine I'm using complains when reimporting such an .fbx (in caps) so I don't mess anything up, but things like this shouldn't happen.
Now I'm checking if I actually selected something using select_pattern after that code row, and if I didn't I raise an exception, but doing this after you used select_pattern just feels strange. I would much rather use try: except:.
Operator's return value is not only used for making decisions in the user's code, that return value is mainly used by the WindowManager to make decision how to unroll even handling after the operator's exec() finished, whether stuff needs to be put to undo buffer and so. Changing behavior of particular operator for a specific usecase is quite unlikely. You will really quickly run into conflict of interest of different script writers.
So just stick to the current design decision and live with that would be my suggestion.
