Selection in Wireframe mode fails with Multiview enabled #51354
Reference: blender/blender#51354
elementaryOS 0.4, GTX 1080
Broken: 2.78,
0fbce63
When looking through the right eye camera of a scene that has multiview (stereoscopy) enabled I cannot properly select objects by clicking on the wireframe. Looking through the left eye it works fine. It seems as if Blender is using the left eye camera by default for everything, including setting the 3d cursor.
Open his file: stereo_selection_fails.blend
Try to select any of the cubes by clicking exactly on the wireframes while looking though the camera: it will fail. If you click a little bit to the right of each wire it works, because selection seems to use the left eye camera. After switching to the left eye view in the stereoscopy panel the selection works fine.
If this is made so by design then it is poorly communicated to the user. Ideally though it should just work :)
Added subscriber: @sebastian_k
Added subscriber: @dfelinto
When looking through one of the cameras, selection should work flawlessly.
Do you have the same issue with either selection mode (OpenGL Select and Occlusion Query)? Also can you try master (from builder bot) and the "Depth Buffer" selection option?
Just tested 2.78c, it's the same there. Also with all selection options.
Actually I found out something else: It seems to rely on the Pivot option. If I set pivot to the right camera and choose right eye view in stereo panel, it works fine for the right eye, but not for the left. Also the placement of the 3D Cursor happens accordingly. If I set Pivot to center I have to click in between, kinda, to get selection to work.
This issue was referenced by
62aa925c11
