Remove doubles Operator crash called from a script in a specific case #51483
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#51483
Win 7 64 bit, Amd X3 455, R7 360
Broken:
717d85f
,ac880b6
Using both the operator and Bmesh Remove doubles variants in a script on a specific mesh in a specific location, can cause Blender to crash
Enable Edit Tools 2 add-on > Default cube > Edit mode > Mesh Edit Tools in the Tools Region (T panel known among the people) > Edge Tools > Roundify ( default settings) > Edges(s) to Wall.
The error:
After some investigation the culprit is in the mesh_to_wall script.
Changing the code in the MeshtoWall operator - moving the remove doubles code to be called first in the execute would prevent crashing.
It didn' matter if the bmesh.ops was replaced with the bpy.ops. However, just commenting out the
bmesh.ops.remove_doubles
line is enough to make the operator run properly.Original code around line 190 (crashes) :
Modified code (doesn't crash)
Concerning the output from the Roundify operator (class EdgeRoundifierin the script
mesh_edge_roundifier
) the produced mesh is valid as other tools are capable of further edits.Commenting out the
bm.free()
line at the end of the operator doesn't have any impact on preventing the crash.Changed status to: 'Open'
Added subscriber: @VukGardasevic
Added subscriber: @BrendonMurphy
confirmed.
Will also note that neither addon is designed to work on solid mesh.
I think we need to fix this asap.
Added subscriber: @Sergey
@BrendonMurphy, you are listed as an author. So assigning to you.
hi, @Sergey, I have discussed this with @VukGardasevic we will have ready.
I've found the actual offending line is line 200 in mesh to wall.
changing this line to:
is a hacky way to prevent the crash, but works & exposes the value error 0 addon fail.
this should be handled by an exception & the user warned "Zero Area faces, please use on single axis" or other pop up warning & the addon pass/prevent execute.
thanks, looking into it more before committing.
Replaced the original script with the a new bmesh operator variant. See in the previous commit.
Since the script suffered from performance issues too. Now, Mesh to wall can be added to contrib as the replacement module is not a 1 to 1 replacement as it does things differently.
@BrendonMurphy
if it is okay we could add it back to the contrib if someone is interested in maintaining/fixing it - fix the bad memory access of the mesh elements and improve performance.
I'll leave this task open until a solution to the script in question is found.
go ahead & close
your rewrite is very good, mesh to wall does do things slightly different, but it's not developed outside mesh edit tools, so, no need to move to contrib.
Thanks. great Job :)
If someone wants to pickup the Mesh to Wall add-on feel free to do so and it will be included back in contrib.
All right i'll archive the task then :)
