failing unregistration lead to crashes in several addons #51547
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#51547
all
Broken: latest master
Those addons don't properly unregister everything, leading to crashes and possibly user pref/keymap corruption:
NPStation (solved)
archipack (solved)
add mesh: castle
measure panel (solved)
dynamic context menu (in interaction with other addons)
layer management (solved)
animated text
kjartan's script (solved)
autotracker (in interaction with other addons)
creaprim
activate and then deactivate one of this addon. If you save userpref after it, your user preferences may be corrupted. Only deleting it works then.
Added subscriber: @bliblubli
Added subscribers: @Okavango, @BrendonMurphy, @VukGardasevic
Removed subscriber: @bliblubli
hi, will look, can we have some more information?
lijenstina has been working on reg issues, although i'm not finding any issue with dynamic context menu.
@bliblubli are you talking about search for unknown operator on unreg?
I'm speaking about addons that don't support to be reloaded. The new template system allows to have different addons activated depending on the startup file chosen. It sometime lead to reloading addons (like F8) and crashes when those don't correctly reload.
Hi @bliblubli, can't reproduce the problem, what kind of console error do you get?
Hi @Okavango , can't reproduce either in latest build, I must have had an old build somewhere. Updated task.
I tested the other ones again to see if the new build solve the other problems:
measure panel support F8 now as long is it was not activated, otherwise, creating a new file or reloading give this error:
@BrendonMurphy creaprime, castle and animated text stil have reloading problems, other are solved :)
@bliblubli
I'll look at the problem next week after some remaining fixes for the release add-ons. By bcon4 this will be addressed :)
hi, thanks for heads up & fixes
ok, tested a little bit more. Some errors only show up when other addons are activated. An easy way to see it is to activate all addons and press F8, then you get the errors form castle, creaprime and animated text plus this:
So autotracker and dynamic menu also have reload problem under some circumstances.
There are no traceback for erta mesh but this line:
Full log is here if you want: http://pasteall.org/407502
Added subscriber: @Sergey
Is anyone actually solving these problems?
Added subscriber: @MauriceRaybaud
Note - the warning:
comes from here , as the PovRay add-on enables/disables Mesh Extra Objects.
@MauriceRaybaud could the
wm.addon_userpref_show
operator be used instead similarly to the CrackIt add-on?Done. Thanks
Thanks for the fix:)
@bliblubli
If you have time, can you please test if now there are more problems with the register / unregister / reload all add-ons?
Thanks in advance :)
hi, is this resolved for 2.79 release?
I think it is safe to close. Maybe waiting for a day or two after RC 2 release. :)
Well since 2.79 is released, we can close this.
For the current possible problems with master we can use #52564 instead.
