Rework our ID copying code #51804
2 Participants
Reference: blender/blender#51804
Problem
So, since I've been working on assets and even more on static override, I came over and over across annoying limitations and oddness of our current ID copying code. To summarize current status:
That somewhat messy and incomplete situation has been annoying me ever since I reworked/factorized other parts of ID management code, but always decided that was low-priority TODO. Now that am working on static override, am hitting issues here more and more, having to add stupid hacks to work around them. And now looks like @Sergey is also facing same kind of issues while working on DEG/CoW.
Proposal
So looks like it’s time to tackle this, and would rather have some consensus on general plan before I start implementing it. I think we need a flexible system allowing to add more copy types/options as need arise, so I would go with flags. I would also try to avoid as much as possible API breakage, due to how many other branches would be impacted, so keeping current API mostly, as wrapper around new one (we can always cleanup later, once transition to 2.8 is finished).
So something like that in main BKE_library api:
BKE_id_copy(struct Main *bmain, const struct ID *id, struct ID **newid, const bool test, const int flag);
NULL
flag
would be same default, full copy as currently withid_copy()
. Options would be mix of generic ones, and some specific to some IDs/usages, e.g.:/* Generic options (should be handled by all ID types copying). /
LIB_ID_COPY_NO_MAIN = 1 << 0, / Create copy outside of any main database - similar to 'localize' functions of materials etc. /
LIB_ID_COPY_NO_USER_REFCOUNT = 1 << 1, / Do not affect user refcount of datablocks used by copied one. /
LIB_ID_COPY_NO_DEG_TAG = 1 << 2, / Do not tag duplicated ID for update in depsgraph. /
LIB_ID_COPY_NO_ALLOCATE = 1 << 3, / Assume given 'newid' already points to allocated memory for whole datablock (ID + data) - USE WITH CAUTION! */
/* Specific options to some ID types or usages, may be ignored by unrelated ID copying functions. /
LIB_ID_COPY_NO_PROXY_CLEAR = 1 << 8, / Object only, needed by make_local code. /
LIB_ID_COPY_NO_PREVIEW = 1 << 9, / Do not copy preview data, when supported. /
/ ... Most likely more needed ;) */
Then add new
BKE_material_copy_ex()
,BKE_object_copy_ex()
etc. that will take same flags as parameter, and behave accordingly.I think we should also store those copying flags in ID, as runtime data, it has at least two benefits:
Finally, once ready, would aim for this branch to be put into master - but after 2.79 release obviously!
Note that, even though new copying with NO_MAIN/NO_USER_REFCOUNT should behave very similar to them, I do not plan to include existing
localize
functions in that refactor for now. Ultimately this should be possible, but those have very specific behavior for very specific use case, so would rather not touch them at first.Things to check
Read again NodeTree localize function, and that one is using a mutex… so was wondering, especially in the DEG/CoW context, whether we may need some 'lock during copy' protection in general? Or should this be handled by DEG itself already?
Added subscribers: @Sergey, @mont29, @ideasman42
Some preliminary feedback.
There's a bit more tricky part about DEG/CoW: ideally i'd want to copy datablock content to a pre-allocated memory. This is because memory is allocated at DEG construction time (so we can know pointers to be passed to evaluation functions) but actual content copy happens during evaluation, and happens in threads.
Similar thing would also need to be done for datablock freeing, which is currently also requires bmain and additionally does depsgraph tagging. Btw, DEG tagging should also be probably added to a flags.
Flags approach seems totally fine to me: avoids having fevzillion functions doing similar thing differently or having lots of function arguments which will also become PITA to maintain.
As for localization: surely it's simple to say "we'll just let DEG to handle that" ;) Surely you can construct a separate depsgraph of a single node tree datablock in it on shading/compositing job begin. but tricky thing is: localization has feature of merging data from evaluated tree back to the original one. Depsgrapgh will unlikely to support such feature.
Semi-related thought here: was thinking, shall we get rid of switch statements in lots of places and introduce some sort of ID type registry, where we store what functions are responsible for copy, free, allocate?
Since copy takes a pointer-to-pointer for new (copied) ID, nothing prevents from adding a
option and assume givennewid
already points to valid allocated memory I guess? What would you expect to happen with sub-data (non ID structs), though, I’d assume those should be duplicated as usual (i.e. allocated and copied as needed byBKE_<idtype>_copy()
function)?Good point, there should also be an option to avoid DEG tagging.
Maybe I was not clear enough here: what I mean is that combination of NO_MAIN/NO_USER_COUNT copy should behave and give pretty much same result as what our localize functions produce currently. But I would not bother trying to make those existing localize functions using new API at first (because it's quite intricate and complex code, easy to break, and not crucial to factorize into new system imho).
No strong opinion here really… would not consider this high priority anyway ;)
That is tricky.. Ideally, DEG CoW should be smart enough about geometry arrays, and have
CD_REFERENCE
of those to the original data, similar to howDerivedMesh
is doing for the case of Mesh without modifiers. On another hand, i'd want things like Pose to be duplicated -- it is light weight anyway.But that being said, i think it is reasonably to state:
only skips ID allocation, but all nested data is allocated and duplicated as usual. If someone needs to do something crazy -- it is all up to him to implement that on his end.Will keep generic API clear to follow. No need to complicate it just because of some specific crazy corner case.
Added subscriber: @dfelinto
Agreed! :)
