Eevee: Animated Eevee values slowdown. #51925
Reference: blender/blender#51925
Eevee is recompiling/linking the shader every frame if one of the values is animated.
Playback this file with a cube and keyframes in the metallic input of the eevee shader, it gets really, really slow:
animated_metallic.blend
Added subscriber: @dfelinto
Confirmed in both NVidia and AMD. On NVidia at least since the shader is eventually cached, the second playback runs smoothly.
Added subscriber: @Sergey
@Sergey, in the new depsgraph (2.78 --enable-new-depsgraph, or 2.8)
material_changed
is called every frame if one of the node elements is keyframed, even if it's a dynamic uniform.Since
GPU_material_free
is called in this function, the shaders have to be re-compiled every frame, leading to a massive slowdown.This is caused by code which ensures changes in node groups properly triggers viewport update of Cycles, which required adding relations between all node trees and material they are used in. As a side effect, this exposed really weak aspect of editor ID update callback system: the callback is called for any ID when any update is flushed on it, without distinguishing source or purpose of the update.
One of the ideas here will be to get rig of editor ID update callback and do everything from dependency graph updates, by splitting material update into two separate operations: one for building actual GLSL shader and one for updating parameters of existing GLSL shader. This will require the following bits to be implemented:
GPU_material_free()
from material rebuild operation.DEG_id_tag_update()
, so we can differentiate between updates which needs to re-build GLSL and which only needs to update parameters.All those are rather simple steps, but we need a working parameters update without GLSL re-compilation first. Otherwise any work we do about this bug report will effectively revert to old depsgraph behavior which does not do any material updates on playback and doesn't trigger updates on node groups changes.
Added subscriber: @MikePan
This issue was referenced by
dfcb568c16
Added subscriber: @JanisGrinvalds
This comment was removed by @JanisGrinvalds
