particle evaluation order is wrong when viewport visibility is off #51997
2 Participants
Reference: blender/blender#51997
Win7 x64
Broken:
3361f21
This report follows https://developer.blender.org/T51977. Now particle render with new depsgraph, but if modifiers visibility for viewport is off, there evaluation order is wrong. The order is good if the visibility is then switched on and off many times, until they appear at the right place.
If the subdivision modifier is hidden in viewport, the particle system is evaluated, but at the wrong place. Only solution is to manually make it visible in viewport and change something that triggers a new evaluation many times, until it updates (like setting the particle system on and off. In some case, it has to be done 3 or 4 time to really update the particles positions)
This is the correct render after the hack explained above
This is the old and new depsgraph with modifiers evaluated in the wrong order
bug part new depsgraph.blend
Added subscriber: @bliblubli
edited task description to reflect last fixes to the new depsgraph.
This is limitation of current design, which doesn't allow clear separation between viewport and render resolutions and everything. Similar issue will happen with boolean modifier which uses subsurf-ed operand. This is something what is being completely reworked in 2.8 branch and i'd rather not attempt to fix this before that rework is done.
