Blender 2.78.5/2.79 - Cannot switch to OpenCL render. #52095
Closed
opened 2017-07-17 20:10:49 +02:00 by SA · 9 comments
Windows 10 Home 64 bit Build 14393.
GPU is an AMD R9 390 running on an older Crimson driver (16.7.1) because of stability reasons.
Broken: 2.78.5 4e22e24 and 2.79 248bba81e7
Worked: 2.78c e92f235283
I can't change the Cycles Compute Device to OpenCL and use my GPU for rendering. Earlier versions work fine. I want to use these versions because of the Principled BSDF shader but it's not really of any use if I'm stuck with CPU render.
Let me know if you need anymore info.
Screenshot: http://i.imgur.com/8TDZVSo.jpg
**System Information** Windows 10 Home 64 bit Build 14393. GPU is an AMD R9 390 running on an older Crimson driver (16.7.1) because of stability reasons. **Blender Version** Broken: 2.78.5 4e22e24 and 2.79 248bba81e7a Worked: 2.78c e92f235283 **Short description of error** I can't change the Cycles Compute Device to OpenCL and use my GPU for rendering. Earlier versions work fine. I want to use these versions because of the Principled BSDF shader but it's not really of any use if I'm stuck with CPU render. Let me know if you need anymore info. Screenshot: http://i.imgur.com/8TDZVSo.jpg
Author
Author
Added subscriber: @MangoJam
Added subscriber: @brecht
For Blender 2.79 we enabled more features in OpenCL to be on par with CUDA, but this also means we also require a recent AMD driver versions to have it all working correctly. Is upgrading to the latest driver really not an option?
Author
Ah, I see. The reason I don't update is because of a problem I've had, twice actually. After the drivers were installed and the the BIOS showed up the screen would keep turning on and off and I couldn't get the security options to show. Then I got the idea to take out my GPU and switch my display to the CPU and rollback the driver which worked. This happened once when I manually updated and the second time when Windows Update was being too efficient. It was just a pain and achieved nothing.
I'll try updating again since I do really want to use the new shader and if OpenCL is on par with CUDA now that's just icing on the cake.
Now that I think about it it might have been a driver conflict, even though the installer said it was removing the old one, I'll remove current drivers manually and then update.
Thanks for the info!
Ah, I see. The reason I don't update is because of a problem I've had, twice actually. After the drivers were installed and the the BIOS showed up the screen would keep turning on and off and I couldn't get the security options to show. Then I got the idea to take out my GPU and switch my display to the CPU and rollback the driver which worked. This happened once when I manually updated and the second time when Windows Update was being too efficient. It was just a pain and achieved nothing. I'll try updating again since I do really want to use the new shader and if OpenCL is on par with CUDA now that's just icing on the cake. Now that I think about it it might have been a driver conflict, even though the installer said it was removing the old one, I'll remove current drivers manually and then update. Thanks for the info!
Added subscriber: @Sergey
Sergey Sharybin self-assigned this 2017-07-18 10:22:55 +02:00
This is likely a result of 1f0998b. The reasoning behind that commit is:
  • We did lots of changes to Cycles OpenCL to bring performance up on AMD GPUs.
  • Those changes made older drivers to work unreliably, often producing render artifacts and crashing.
  • Those older drivers are not supported by AMD.
  • There is no simple workaround to make those drivers to work.
So instead of investing unreasonable amount of time trying to workaround unsupported platform (which would likely cause performance loss on a newer driver/cards) we decided to stop supporting those: performance wise and feature wise we can't bring Cycles on older hardware/drivers more further than 2.78 release anyway.
So thanks for the report, but we can't make such configurations to work with Blender currently.
P.S. This change is listed in the release logs there https://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.79/Cycles#OpenCL
This is likely a result of 1f0998b. The reasoning behind that commit is: - We did lots of changes to Cycles OpenCL to bring performance up on AMD GPUs. - Those changes made older drivers to work unreliably, often producing render artifacts and crashing. - Those older drivers are not supported by AMD. - There is no simple workaround to make those drivers to work. So instead of investing unreasonable amount of time trying to workaround unsupported platform (which would likely cause performance loss on a newer driver/cards) we decided to stop supporting those: performance wise and feature wise we can't bring Cycles on older hardware/drivers more further than 2.78 release anyway. So thanks for the report, but we can't make such configurations to work with Blender currently. P.S. This change is listed in the release logs there https://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.79/Cycles#OpenCL
Author
I understand. Thanks for the reply; I'll just try and get the driver to work.
Reference: blender/blender#52095
