Crash on entering Edit Mode of high poly mesh used by Shrink Wrap #52149
6 Participants
Reference: blender/blender#52149
System Information/Blender Version:
Win8.1x64, 3x gtx580:
Ubuntu 14 x64, IntelGMA:
Entering edit mode on particular relatively high poly mesh, used by Shrink Wrap modifiers, crashes Blender 2.79 test build 2. If Shrink Wraps using the mesh are disabled - no crash. No crash on a much weaker virtually GPU-less Ubuntu machine or both machines in 2.78c.
Running from cmd:
err3b.blend
Added subscriber: @KonstantinsVisnevskis
#52544 was marked as duplicate of this issue
#52353 was marked as duplicate of this issue
Added subscriber: @fablefox
I tried with latest daily build and didn't crash. Win 7 + GTX 750.
Daily build (e 982ebd) crashes for me.
OK. I can confirm this. Apparently, the crash might be random for me. I was testing writing debug log to disk, and changing to Edit Mode cause Blender to close with the error you mentioned.
Note to developer:
Try testing this multiple time if the first time didn't cause a crash. Maybe the first time changing the mode didn't cause a crash, but it might do something to memory. But subsequent opening the file and changing the mode will cause blender to crash with EXCEPTION_ACCESS_VIOLATION.
Also of note, Blender crash that involve such error doesn't flush error or anything to the text file, even if cmd box is OK. test2.txt remains empty.
OK. This bug is really strange. If I run blender -d without piping to text file, I get the original result as the first time testing this bug (no crash).
Another note, now that I try with piping to text again, no crash.
Conclusion: I can confirm this bug, but for me apparently its quite random...
Added subscriber: @mont29
means Blender tries to access invalid memory - typically already freed one.Could be a threading issue e.g., can you reproduce it with
-t 1
option? Also, @fablefox, if you have a debug build of Blender, you should be able to use MSVC debugger to precisely locate the bug?Added subscriber: @LazyDodo
@mont29 here's a stackdump
looptri is pointing to invalid / freed memory.... don't know the code well enough to actually fix the bug here.
Added subscriber: @mano-wii
In my case, the looptri 553472 is pointing to the loops {4261281277, 0, 0} :\
I made these changes in the code and the problem was solved!:
I don't know why this change fixed the bug, but I've seen something that goes against the main goal of multithread, the performance.
In the file, two objects have the Shrinkwrap modifier with the high-poly object as target, so that two threads execute the code that searches the looptris of the high-poly object.
The problem is that the two threads execute the same
ccgDM_recalcLoopTri
function so one waits at the beginning of the function, to repeat it as soon as the other ends (BLI_rw_mutex_lock).This repetition is a total waste of processing. So it should be avoided.
Added subscribers: @Sergey, @ideasman42
Thanks for the investigations so far. :)
The problem is thread concurrency, as usual:
getLoopTriArray()
, which finds lopptri array is NULL and needs to be computed.recalcLoopTri()
and locked the RWmutex.Note that this is just an example, order could be totally different here, point is, there is no real protection against concurrency here.
Your solution works, but only in that specific case - if someone calls
recaclLoopTri
without passing bygetLoopTriArray()
, you'll again get concurrency issues.I think proper solution here would be to not expose
recalcLoopTri
at all in DM API, and instead feature aninvalidateLoopTri
callback tagging the looptri array as needing recomputation. That way, bothget
andinvalidate
functions could do proper lock and safetycheck inside locked area, to ensure they do not tip over other threads' toes.recalcLoopTri
would then just be internal static helper. Note that you also have to handle CDDM and EMDM!@ideasman42, @Sergey, thoughts?
Added subscriber: @BrandonGriffin
This issue was referenced by
00cb352790
Added subscriber: @pawelb
