Driven key sticks on certain values #52184
2 Participants
Reference: blender/blender#52184
I ran into some unexpected behavior in a recent project lightwrap_normals_test.blend
Steps for confirming bug:
1: Press 'R' over the 3D viewport to rotate the plane-object around its' X-axis
2: The driven key value in the Graph Editor on the left only updates at certain values; 1.571 (90°), 4.712 (270°) etc.
I have not been able to reproduce the behavior on a fresh project.
System:
Win10, 64 bit
Blender 2.78
e982ebd
Thank you,
Added subscriber: @mstuff
Added subscriber: @Sergey
Thanks for the report, but it's just a limitaiton. Your driver is configured to use object's final rotation as a source, but tricky part is: you are requesting for a particular channel of rotation component. Internally Blender uses transformation matrix to store object's transform, and if individual channels of that transform is needed it decomposes the matrix. This step has some limitation, for example zero scale or negative scale might confuse the system. This is exactly what's happening here: your plane is zero scaled along Z axis.
So thanks for the report, but will not consider it a bug.
I understand.
Thank you for taking the time to look through the file, resetting the scale of the object fixed the issue.
