after boolean snap don't work #52310
5 Participants
Reference: blender/blender#52310
win7 64bit gtx1070
Broken: 2.78c
after the boolean operation, with the modifier still active, the boolean object is not affected by the snap anymore.
move the selected object and you will see that the snaps don't work anymore.
thankyou
snapbug.blend
Added subscriber: @MassimilianoPuliero
Added subscriber: @mano-wii
Added subscriber: @ChameleonScales
This would be understandable as the surface of the object is affected by the boolean object. However it should at least work when the modifier is hidden, which is not the case. We have to remove the object from the modifier or remove the modifier itself.
Added subscriber: @tynkatopi
Added subscriber: @Sergey
Thanks for the report, but it' not really a bug.
What's happening here is that transform system will not allow to snap object which is dependent on currently editing one. This is needed to avoid feedback loops which will ruing your scene. This is done based on dependency graph relations. Those relations are based on modifier stack and not based on modifier visibility flags. Making relations aware of modifier visibility will cause depsgraph rebuilds on every modifier visibility toggle, which isn't really something you want from performance point of view. But additionally, making relations aware of such visibility will make it really hard to spot dependency cycles when some modifier is only enabled for render and not for viewport.
So while this is annoying issue, we can't really make snapping to work here as you expect: if modifier is enabled, then you hit feedback cycle and object will snap to some weird location., disabled modifiers are tricky to support and still somewhat unpredictable and useless for snapping.
