Default Shape Key ID in Keying Set files broken - TypeError: 'builtin_function_or_method' object is not subscriptable
Windows 10
Broken: 2.78c, 2.79 rc1
Worked: N/A
Issue is the following:
I've found that the default Keying set that Blender exports from the Keying Set Panel, when you have shape keys added to the keyset - will pull the following error and be useless:
Error: Python script fail, look in the console for now...
The solution is changing the shape key ID to the correct one:
# Keying Set: KeyingSet
import bpy
scene = bpy.context.scene
# Keying Set Level declarations
ks = scene.keying_sets.new(idname="KeyingSet", name="Keyset_Name")
ks.bl_description = ""
ks.use_insertkey_needed = False
ks.use_insertkey_visual = False
ks.use_insertkey_xyz_to_rgb = True
# ID's that are commonly used
## This is the default in blender, and it is broken.
#id_0 = bpy.types.key["Key"]
### Use this instead:
id_0 = bpy.context.object.data.shape_keys
# Path Definitions
ksp = ks.paths.add(id_0, 'key_blocks["Shape_Name"].value', index=-1)
  1. Create a Shape key
  2. Create a Keying Set
  3. Select Shapekey value and then add to active Keying Set
  4. Export Keyingset
  5. Load python Keyingset and append object with shape key
  6. Run
  7. Error
