Cannot seem to export Vertex Color with Alembic for Maya nor Houdini #52417
7 Participants
Reference: blender/blender#52417
Windows 7, Quadro FX 4000
Broken: (example: 2.69.7
4b206af
, see splash screen)Worked: (optional)
Exporting Vertex Color seems to fail for Alembic. Option already turned on. This should be pretty straight forward. I even try naming it to Cd.
Just Vertex Color paint a mesh and try exporting Alembic with Vertex Color turned on. Does not work when imported to Maya or Houdini.
Added subscriber: @BlenderSushiGuy
Added subscriber: @SteffenD
Added subscribers: @dr.sybren, @mont29
@dr.sybren I’ll let you handle that one. :)
Please fill out the entire form, including which version of Blender you've tested with, which version used to work for you previously (if any), and attach an example blend file.
This seems to work fine in current master (
696f4dc85f
).@dr.sybren I tried the latest "current master" build and still not working. Maybe my compiled is not really latest? May I know at which version exactly that exporting ABC Alembic with Vertex Color is working?
Try either 2.79 Release Candidate 2 or today's daily build. If you pick a daily build, please also report the full filename of the downloaded file, so we know which platform, nr of bits, and the git hash of that particular version.
I tested again today, using RC2 hash
7b397cd
with Houdini FX Apprentice Version 16.0.671, and Alembic Vertex Color is still not transferring. Animation works, but no vertex color, confirmed still an issue.I tested with Blender, exporting a Torus being displaced and with Vertex Color, Import Export works within Blender. Vertex Color is not changing per animation frame as expected, but at least Vertex Color is there.
Can you attach the blend file you used to test? Then I'm sure that we're looking at the same thing.
Added subscriber: @n1ckfg
To make the attached test, I took the same mesh into Blender, Maya, and Houdini, and exported an Alembic file with vertex colours from each; the attributes are all named Cd to match Houdini convention. (In Blender I applied vertex colours with the common Python function below, just in case that's helpful to know.) The results:
Then I ran the output of each through abcls and added the logs to the attachment below. Would love to know if anyone sees something in the way the Cd attributes are structured that could provide a clue.
alembic_vertex_color_test.zip
Here's how vertex colours are represented in each of the Alembic exports. Can anyone tell me why Houdini and Maya can see each other's vertex colours, but Blender's aren't visible in Houdini or Maya? Looking at the logs here, is it just as simple as adding a mayaColorSet=1 flag to the Blender compound property on export?
If I wanted to recompile Blender's Alembic export module with the mayaColorSet=1 flag added, where in the source should I look?
@n1ckfg I think a good place to put that would be in
write_mcol()
.Added subscriber: @dario.seyb
OK, progress--I can build Blender from source with Alembic enabled. Next step, @dario.seyb says for Unity he used the following to add the Maya color set flag:
Could you help me adapt this for Blender in abc_customdata.cc? I'm getting more certain that this is the fix to make Blender vertex colors readable in Houdini and Maya.
Here's what I've got so far...it builds successfully and exports valid Alembic files, but abcls doesn't find the mayaColorSet=1 flag so I'm still doing something wrong.
https://github.com/n1ckfg/blender/blob/master/source/blender/alembic/intern/abc_customdata.cc
Added subscriber: @lichtwerk
some (related?) info in #53745
Oh cool, sounds like folks are on the trail of a solution!
Closed as duplicate of #53745
Added subscriber: @ChristopherAnderssarian
