Setting origin to Center of Mass on zero-volume objects produces wrong results now in 2.79 #52434
6 Participants
Reference: blender/blender#52434
Windows 7 x64
Broken: 2.79 RC
Worked: 2.78c
Setting the origin to "Center of Mass" for mesh objects which are not closed and manifold now produces wrong and inconsistent results. Results even change on repetition.
As a result the origin won't be set to the actual center of the plane. Repeating the last step will change the result even.
The .blend only requires step 4:
median-center-on-zero-volume-wrong.blend
Martin Felke found this bug, thanks to him.
Added subscriber: @KaiKostack-3
Added subscriber: @pixelgrapher
In 2.79 RC2, it appears that repeating step 4 causes the origin to asymptotically move closer towards the center.
Added subscriber: @jta
This issue was referenced by
361c7cbbc5
Added subscriber: @sreich
So I really don't like this.
Setting the origin already has too many options, when is "Origin to Geometry" ever actually useful, especially since we have the "Center of Mass" option.
If anything we should remove the "Geometry" option.
This is not a trivial matter as well, in the past I had several users being confused by this.
If the new method is actually better for solid objects (I would like to believe it since it's the same shoelace algorithm working on tetrahedra but haven't seen the evidence for it) then we should make it work instead of adding another option.
IMO a proper fix would be to figure out why it fails and then either fix it or detect the failing cases and use the appropriate algorithm.
