bake from selected to active gives results that seem bogus #52519
Reference: blender/blender#52519
{F723221}System Information
Linux bubastis 4.0.5-gentoo #2 SMP Tue Jan 3 15:53:31 EST 2017 x86_64 Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz GenuineIntel GNU/Linux
01:00.0 VGA compatible controller: NVIDIA Corporation GK107GLM [Quadro K1100M] (rev a1) (prog-if 00 [VGA controller])
Broken: blender-2.79-rc1 and 2.78c
Attempting to bake from selected to active malfunctions for a group of cylinders.
Specifically "tank lower"* and "tank upper" selected_to_active "tank cluster bake 1".
Select the above-mentioned cylinders that are children of "tank cluster A" and make sure that "tank cluster bake 1" is active. Then use the Bake button in the render panel. The necessary material node and UV map are already active.
The resulting image is not suitable for use as a baked texture (for example on "tank cluster bake 1.002")
Added subscriber: @mutantbob
Added subscriber: @zeauro
Except bad settings and scene set-up, I see no bug, here.
It does not make sense to make a huge margin of 16 px if there is only a space for 2 pixels between UV Islands.
Then, you have to precise a ray distance different from 0 or use another mesh as a cage to precise clipping the same way your camera for common renders has clipping values.
Set it to a distance of 0.1 and you should obtain a decent result.
The distance=0.1 solved the problem on 2.79 rc1 .
I got a SEGV in 2.78c, but we probably don't care about that with 2.79 on the way.
Added subscriber: @mont29
Closing then. Note that we do not handle user support on this tracker, only bug reports. User forums like blenderartists.org or blender.stackexchange.com should be used for that matter.
