Error registering add-on's and other bugs with add-ons in 2.79 master (buildbot)
Windows 10 x64
Renderer: GeForce GTX 860M/PCIe/SSE2
Broken: 2.79.1 b07dcb8
Worked: 2.79 RC2
Register error if two different add-ons have identical class names.
That breaks registration for all of my add-ons.
  1. Open attached blend file:
  2. Run scripts in both Text Editor areas.
  3. You should get register error (like below) while running second script, that doesn't happen with 2.78 or 2.79 RC2.
    File "C:\Users\Username\Desktop\user_pref_error.blend\addon_2", line 20, in <module>
    File "C:\Users\Username\Desktop\user_pref_error.blend\addon_2", line 12, in register
RuntimeError: Error: Type identifier 'Object_A' is already in use: 'Object_A(AddonPreferences)'.
hi @Mikhail Rachinskiy (alm)
the use of duplicate class names has been restricted, we plan to, after 2.79 release, to address these issues.
please note these issues will not be in 2.79 release but are in nightly builds.
it's good to be aware of this issue, i'm trying to keep addons repo clean for 2.79 release, then come in and fix all the issues in nightly, whilst not polluting addons master with fixes that might be conflicting with release.
not closing the task as we may for future ref.
Brendon Murphy (meta-androcto) renamed this task from Error registering add-on's with identical class names to Error registering add-on's with identical class names in 2.79 master (buildbot).Aug 27 2017, 5:20 PM
Brendon Murphy (meta-androcto) lowered the priority of this task from 90 to 50.
Hi guys .. having issue when I enable 'Amaranth Toolset' .. any solution here??
Error code :
  File "/home/model01/Desktop/blender-2.79-9134529b9eb-linux-glibc219-x86_64/2.79/scripts/modules/addon_utils.py", line 350, in enable
    mod.register()
  File "/home/model01/Desktop/blender-2.79-9134529b9eb-linux-glibc219-x86_64/2.79/scripts/addons_contrib/amaranth/__init__.py", line 118, in register
    _call_globals("register")
  File "/home/model01/Desktop/blender-2.79-9134529b9eb-linux-glibc219-x86_64/2.79/scripts/addons_contrib/amaranth/__init__.py", line 107, in _call_globals
    getattr(m, attr_name)()
  File "/home/model01/Desktop/blender-2.79-9134529b9eb-linux-glibc219-x86_64/2.79/scripts/addons_contrib/amaranth/animation/motion_paths.py", line 136, in register
    bpy.utils.register_class(AMTH_POSE_OT_paths_clear_all)
ValueError: register_class(...): already registered as a subclass
@Souvik Karmakar (souvik) the registration issue in master should be solved. Added a versioning code so it should work with 2.79 release too. Please check the next daily build. Sorry for the wait.
Here on Win10 64bit + Blender 2.79.1 (Hash: a466d7a) 64bit portable the Amaranth Toolset add-on is working fine. Thank you for the fix.
Vuk Gardašević (lijenstina) lowered the priority of this task from 50 to Normal.Jan 6 2018, 7:56 AM
Since there weren't new found register errors for a while lowering the priority to Normal. We'll still keep the task open as things can be broken in the future. Well that is not just a possibility, it's the rule :)
To not open an another task we can keep also note of Broken add-ons from master here, since issues like crashing can lead to problems with registering in specific situations.
Vuk Gardašević (lijenstina) renamed this task from Error registering add-on's with identical class names in 2.79 master (buildbot) to Error registering add-on's and other bugs with add-ons in 2.79 master (buildbot).Mar 17 2018, 9:16 PM
Aaron Carlisle (Blendify) closed this task as Resolved.Feb 12 2020, 7:15 AM
Aaron Carlisle (Blendify) claimed this task.
